Coolant Overhaul
ScottD3 Feb 21, 2011
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    I'm planning my next trip to the garage.
    I've done my rear disks, pads and bearings, now i'm doing the coolant system.
    I checked the recipts i got with the car and i can't find any thing for the water pump being replaced. I'm going to get that, my temp gauge jumps from 70-90 or back down to 60 if I idle long enough and Its running on bluecoolant.
    I'm going to replace the water pump, thermostat, temp sensor and the coolant.
    Since all this is being take off and replaced. Any one recomend any other coolent bits thats worth doing at the same time?
    the funds and time let me i'm going to try and get the front braked replaced, fluid change and resivor replaced. Meant to do it this time but ran out of money and time :(.
    Thanks in advance.
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Any belts need doing while the front end is off? Cant really think of any other coolant parts that would need doing.
  3. ScottD3
    15,161
    1,121
    Done all them.
    Cam belt done when i got it, Aux belt done when it snapped just be for christmas.
    Thats my thinking. Front end is off, so might as well make use of it. :)
    I might try and get a AC compressor and get that on as well.
  4. Jason.s
    2,879
    348
    In that case thats all i can think off. Aux belt tensioner done? I know mine was squeaky as buggery so had to change it. I did that at about 106k last year. Snub mount at the front? Its only a few quid from dealers or you could get the APR uprated one from Awesome maybe?
  5. ScottD3
    15,161
    1,121
    Snub mount?
    My tensoner failed and caused the belt to break up.
  6. Jason.s
    2,879
    348
    Ah right.
    yeah the mount at the front at the bottom. Standard one is a squishy rubber donut but the uprated ones are poly so are much stiffer causing less movement when accelerating/letting off giving less movement in the gearstick.
    Well Awesome used to sell it but not anymore it seems.
  7. ScottD3
    15,161
    1,121
    I'll have a look in it.
    thanks.
  8. rossbrownlee
    rossbrownlee Ross_S4
    719
    Back flushing the heater matrix? access to the two connections is easy as.
    I saw a great write up somewhere on-line, you want to have seen the gunk that came out during the flush!
    will see if i can find it again.
  9. ScottD3
    15,161
    1,121
    Be cool if you could. thanks.
  10. rossbrownlee
    719
  11. ScottD3
    15,161
    1,121
  12. nwmlarge
    nwmlarge flat out
    219
    i'm pretty sure you are supposed to run pink/orange coolant
  13. ScottD3
    15,161
    1,121
    You are.
    G12+.
    Blue is what was in the car when I got it and I got 15 litres of blue concentrated coolant from work. Since I was having coolant leak issues at the time I used that.
    Now its fixed I'm going to go pink again.
    I can't find any thing on this snub mount.
    Is there is any aftermarket ones out here?
  14. nwmlarge
    nwmlarge flat out
    219
    awesome do a b6 snub mount under the engine section which i understand some users inc aragon on here have used in the past.
  15. ScottD3
    15,161
    1,121
    Dealer only part?
    Whats the benefits of it?
  16. aragorn
    17,956
    701
    yep, awesome gti used to sell one (listed for the b6), but i've heard they might have stopped listing it.
    Not sure where else you can go.
    Benefits are reduced engine movement basically.
  17. ScottD3
    15,161
    1,121
  18. nwmlarge
    nwmlarge flat out
    219
  19. ScottD3
    15,161
    1,121
    Will it fit a 1.9 TDI?
    It only states 1.8T.
  20. aragorn
    17,956
    701
    should do, the mount on the engine is the same.
  21. ScottD3
    15,161
    1,121
    ok cool.
    I'll add it to the list.
