Coolant loss changing Thermostat?????
S3 Dave Nov 1, 2007
  1. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    I have concluded its my Thermostat that's tired after a few days and using A/c No.49. Digital display and Temp gauge are there or there abouts so sender must be OK. Going to change it at the weekend all being well. How much coolant will I loose???? Should a litre of G12 be enough??? The coolant was changed only about a year ago so not going to flush it out!
    Paid just over £15 for stat and O ring, numbers if anyone needs them..........
    038 121 119 B Washer/ O-ring
    050 121 113 C Thermostat
    :icon_thumright:
  2. Ian W
    Ian W Active Member
    1,058
    12
    Wheres the stat on the S3, simple to get to ?
  3. jbkudos
    jbkudos Member
    85
    where did you get the parts from I need to change mine
  4. abdus
    abdus Top Gear VCDS Map User
    1,827
    Open the collant bottle to depressurise the system completely and close it, there will be some loss of coolant, but 1 litre should be fine i guess
    vagparts...or your local dealer
  5. S3 Dave
    432
    See previous posts for stat position. Its left hand side of block by alternator. Got the parts from local VW dealer. Will get some G12 when i collect the parts!
