Coolant Loss! 1.8T
jcp May 8, 2008
  1. jcp
    jcp New Member
    10
    Hi all, first post and got a problem.
    I seem to be losing a lot of coolant on a daily basis. More than a pint or two.
    I can not find the exactly where leak is coming from, but it looks like its coming from the bottom front. I guess this could be the rad, but do you have any other suggestions?
    Water is clean with no sign of oil contamination.
  2. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Could be the Common housing at the rear of the engine, cant quite remember what its called now though..
  3. jcp
    jcp New Member
    10
    Yea, I had a good look at the coolant flange, but it seems good. Only losing water when the engine is running if this helps?
  4. jase0851
    jase0851 Member
    789
    if your only loosing water with the engine running and at the bottom front i would be inclined to think it would be the radiator
  5. jcp
    jcp New Member
    10
    Thanks, that's my thinking also. Can I use Radweld, if so where should I pour it.
  6. J7USS
    3,737
    77
    yeah Ill go with Jase on that one then if you already checked the Flange:)eyebrows:) Loosing a Pint or 2 is not good,especially in this weather!!
  7. J7USS
    3,737
    77
    Wouldnt bother with Radweld, doesnt sound like a Small hole to me, Loosing way to much fluid.
    New rad my friend....
  8. jase0851
    jase0851 Member
    789
    ill second that, a new rad needed then jcp
