Yes, that will be more than enough. The cooling capacity is about 5 litres. You have 3 litres of G12+ which would give you a 60% mix (this is assuming the system is completely dry before filling. If there is residual coolant in the block or heat exchanger, then the mix will be more that 60% G12+"
Mixture should be at least 40%, but no higher than 60% as boiling protection is reduced.
I would mix your G12+ with water to 40% in a separate container and then add it to the engine. You know you will have the correct mix then.
G12+ (40 %) and water (60 %) for frost protection to 25 °C.
G12+ (50 %) and water (50 %) for frost protection to 35 °C.
G12+ (60 %) and water (40 %) for frost protection to 40 °C.
