Coolant level warning, temp gauge reading 120c!!!!
Maz Oct 3, 2011
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Morning all, I've had this issue with the car for the past week now and need some pointers as to what might be causing it.
    All is well when the car is moving but once sat in a bit of traffic or at the lights the gauge starts rising rapidly hitting a worrying 120c.
    In the past week I've had to pull over at least four times to let things cool down before moving on.
    I've also noticed the fans are not coming on at all, somethings up but I don't have a clue. Any ideas?
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Check the fuses on top of the battery, pull them out and look for melting fuse holders...
  3. Maz
    1,002
    10
    lol, will do mate.
  4. colicabcadam
    colicabcadam Guest
    exactly what s3 dave said, they melt and although the fuse does not blow, the melted plastic causes resitance
    get some solvent on the contacts in the fuse box and some cotton buds before you put new fuses in.....
    i had the exact same problem, AA man said the fuses were ok, after a new fan control module and various other attempts, i thought what the heck, i'll check the fuse, tada!
    also, does your aircon come on? if it does, sadly it isn;t a fuse.
  5. Maz
    1,002
    10
    Will check in the next half hour and report back.
    Thanks guys.
  6. aragorn
    18,019
    716
    If it happens again, crank the heater up to full hot and ramp the blower fan up to max to keep the engine temp under control (and open the windows so you dont melt), 120c is head warping territory, and shutting the engine off to let it cool down will cause the head temp to increase even further due to heat soak and no water flow.
    Your engine requires the fan to work to keep it cool when stationary or moving slowly. The natural airflow thru the rad is non existant, so the temperature just climbs and climbs. As folk have mentioned, you need to get the fans working.
  7. Maz
    1,002
    10
    Top marks for the diagnosis peeps, as you can see the pesky fuse holder has melted.
    I've also noticed some coolant leakage, above the fan and on a part (3rd pic) not sure what it is??
    I've since cleaned the fuse holder area and replaced the fuse.
    Checked Air con which works fine and left the car running for 10 mins to see if the temp gauge would rise and if the fans would kick in. Well the temp stayed dead on 90c but the fans didn't start at all so not sure where to go from here.
    Thanks again guys, much appreciated!
  8. s3dave
    10,110
    736
    Did the fans come on with the aircon? if so it might be sufficient for the engine cooling, go for a drive then leave it ticking over without aircon and they should come on, keep an eye on the temp though.....
  9. Maz
    1,002
    10
    Yes, just checked and both fans are spinning with air con on:icon_thumright:.
    I can't go for a drive right now but will do later this evening to carry out the ticking over without air con test. If the fans do come on after the test can I safely assume it's all sorted now and blame it on the melted fuse holder???
  10. s3dave
    10,110
    736
    Yep, just keep your eye on the fuse holder and ideally replace...
  11. colicabcadam
    colicabcadam Guest
    ok - the gauge on the dash is ****, it stays at 90 even if the temp is between 80 and 110 i believe
    get a digital reading by doing the following.......
    with the aircon and climate control settings off - hold the recirc button and press the up arrow on the climate control, you'll notice a change on the display, now use the temp + button to go all the way up to 49, then press the recirc button again, the setting you now see is the temp of the engine temp sensor
    let the car tick over, it should reach around 105 - 107 before the fans kicks in and it drops back down to 95ish
    you may need a new coolant cap as the seal can get damaged due to the pressure at 120c, so in theory you loose pressure
  12. Maz
    1,002
    10
    The fans seems to be working as they should do having carried out the suggested tests and I haven't experienced any overheating since. I plan to get a new holder asap as well.
    ...you guys as well as other knowledgeable contributors are the reason why I just Lurve AS.net!!!
