Coolant leaking from the coolant tank A4 B6 1.9 TDI
delc83 Dec 19, 2013
  1. delc83
    delc83 New Member
    19
    Hi Guys
    Audi A4 B6 1.9 TDI 130, AVF, 2004
    I've noticed coolant is leaking from the hole under the coolant tank, when ive been driving, it isnt loosing much at the moment, but when I open the bottle pressure comes out and the coolant rises.
    Ive have replaced the coolant tank with a new one, still leaking.
    I've also replaced the thermostat (genuine), temp sensor, because it wasnt sitting at 90, but is now.
    Earlier this week water pump failed, so got that replaced, even though it was replaced at 115k, 7 months ago.
    It is still leaking and the coolant has gone a bit dirty, ive had the sniff test done, and it didnt show any hydro carbons, and the colour didnt change and also pressure test on the coolant bottle and pressure was fine.
    Hope its not the head gasket, my friend said it could be the oil cooler.
    Any help or guidance would be appreciated.
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,677
    634
    I had the same problem and it was the HG, its one of the only ways to pressure rise the coolant system and water to be forced out of the coolant bottle, only other cause than I can think of is a cracked head.
  3. delc83
    delc83 New Member
    19
    How much did it cost?
  4. B5NUT
    3,677
    634
  5. Mollygoogle
    Mollygoogle Member
    227
    Just had the same symptoms with mine and it was the head gasket. Hopefully yours works out better than mine has so far
  6. pauldazzle
    pauldazzle Well-Known Member
    1,122
    80
    Head gasket failing.
  7. delc83
    delc83 New Member
    19
    I just dont want to get it opened and have a cracked head.
    Is £300-£400 a good price to get the HG replaced? a mechanic said sometimes injectors fail when replacing the HG, ive also been told skimming the head isnt a good idea on a PD engine, is this true?
  8. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,170
    150
    Did you replace the cap?
    BakPak likes this.
  9. delc83
    delc83 New Member
    19
    Yes i replaced it with my mates, ive noticed the pipe thats connects to the radiator goes really hard when ive been driving around. its building pressure, only way to let it out is to open the cap, and some air and more coolant comes out the hole from under the tank, and the pipe goes soft again.
  10. BakPak
    BakPak No Gear
    957
    136
    43
    Had very similar problem with mine, 1.9tdi 130 5 speed. After giving the coolant system a dose of K-Seal no problems since. Done approx 500 miles. Mark.
