Coolant Leak... Help with part name/number
Maz Apr 3, 2012
  1. Maz
    Maz Moon is made of green cheese
    1,002
    10
    Hello,
    I noticed this part was leaking a while ago and now that it's getting worse I want to replace it asap.
    Can someone help with the name/number of the part, how much it its likely to cost to replace, is it worth replacing with a genuine part and is it an easy DIY fix?
    Thanks.
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Looks like the water over run pump for the turbo. Definately worth replacing, probably an expensive item new to be honest so might worth getting one of a breaking S3 imagine it would be cheap though as not exactly a desired item.
  3. Maz
    1,002
    10
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  5. beachbuggy
    1,931
    201
    Only thing I would add to that write up is to drain the coolant first with the drain on the bottom of the radiator, do it with the cap of the expansion bottle and as the pump is pretty much the top of the system when you remove the pump you should lose next to no coolant.
  6. Maz
    1,002
    10
    Just called a local breakers yard and they have one available for £40 with a three month warranty.
    ...Audi want £125 for it.
  7. Sevv
    Sevv Pushing the limits..
    1,324
    120
    id buy a new one and have the piece of mind but thats just me :p
  8. Maz
    1,002
    10
    Normally so would I Sevv but on this occasion I might give a second hand part a go depending on it's condition.
