Coolant leak from trans tunnel and pics of cleaning battery drain.
nogmeg Jul 8, 2012
  1. nogmeg
    nogmeg Member
    35
    Hello, I have a coolant leak behind the back of the engine. It's coming from an opening along the bottom corner of the tunnel that humps up over the drive shaft and exhaust system. There's an area between two pieces of sheet metal that flares open to create what looks like a it could be a drain that measures maybe 3/8" by 1.5". hidden under a pice of exhaust heat shied. I see no evidence that the coolant is leaking farther forward. It an odd place so I don't want to blame it all on the heater core. The coolant just dribbles out that opening.
    Leak is minimal with engine off, under pressure becomes empty after 10 miles of driving.
    I have since bypassed the heater core and leak has stopped, so it's something beyond my bypass.
    Just to be safe I cleaned out the drains that were a little blocked under the battery and brake servo. As these being blocked can lead to water in the footwell. here are some pictures if anyone else is interested in cleaning out theirs the drain on the left can be tricky as taking out the break servo is a major.
    - Battery removed.
    - Under the ECU cover.[​IMG]
    - Drain under the brake servo, tricky as pipe doesn't allow you to remove it to clean it out.
    It's obvious I need a new heater core, as I have all the tell tell signs of this. fogging windows, coolant smell, etc.. plus the male heater core pipes are ruined.
    However my question is are there any other pipes/hoses coolant related that could be causing this leak into the passenger footwell and out of this drain under the car? As it would be a huge PITA to remove my dash, change the heater core and still have my coolant leak. Could it be a pipe around the centre console / transmission tunnel area or something at the back of the engine.
    Looking through other threads people with similar problems suggest these possible problems:
    aux. colonat pump
    coolant flange
    water pump
    oil cooler
    heater core
    I think the key to this problem is the black drain in the transmission tunnel, whatever is inside it, as this is where the coolant is coming out.
    Cheers, hope the drain photos are of some help to anyone needing the clean and unblock this area.
  2. murran
    murran Well-Known Member
    1,545
    39
    i suspect the drain your on about is the condensation drain from the heater box. it does normally drip water when the engines running and the aircon is on..... but deffo not coolant.
    dash and heater box out.... its quite a nice easy satisfying job actually, ive done a couple at work. and you dont really need much more tools than a couple of screw drivers and an 8mm+10mm quarter drive/ratchet/extension etc.
    if you were alot nearer me id come give you a hand for a day.
  3. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Hey,
    I was looking for that pipe here Air Con drain :ninja:
    Hope you get it sorted!
  4. nogmeg
    nogmeg Member
    35
    hmm, ok I'll read up on condensation drains, see if anyone else had a coolant problem, down there.
    Hahaha satisfying, your the first person to have a positive outlook on a heater core change. Thanks for the offer, that's very kind of you, shame your not closer. I'll keep procrastinating, got a few months before winter.
