As in the title guys, found a coolant leak recently, not massive but over the course of 6-8 weeks it drops from max to just below min, also found water on the undertray when I removed it earlier this week.
having had a good old snoop with my led endescope I can see water leaking from a joint section just behind the top of the block, checked with parts diagram and it looks to be part 44, so I've ordered it along with O-rings, it may just be the actual seal or seals that are dripping but at £8.00 plus the vat seems bonkers not to replace the whole part.
I assume this part is attached to the block and water coolant passes throught it into block or vise-versa judging by the diagram.
Now the bigger question, this llooks to be a real pain to replace due to lack of access, is there a prefered method of removal/refit or just a struggle and swear at it plan, any info or thoughts chaps would be nice.
pic of the offending part (44):
