Coolant flashing up ? 2.0 tdi Quattro
Baza1819 Jan 22, 2013
  1. Baza1819
    Baza1819 Member
    254
    When I'm driving my dash keeps lighting up saying coolant. If I stop & look at bottle while engine running it looks well below level. If I open the cap I get a swish of air & the water rises to the correct level ? Does the same when I turn engine off !
    Yet the temp gauge never moves from 90* ?
    Please any would be very much appreciated.......
  2. Manni.singh
    Manni.singh Member
    53
    Did u check it when car was hot? Check it when it's cold, when I checked mine when was hot went to correct level, when I checked when it was cold, was below the level by a lot, I had same issue, it got to a point where I had to keep refilling every 40 miles, got some Halfords weld thing that u put in the tank and haven't filled up since,
    Baza1819 likes this.
  3. Baza1819
    Baza1819 Member
    254
    Am at a Audi specialists now - main dealers are idiots wanting £80 an to investigate. Free diagnosis here !!
  4. bonerp
    bonerp Member
    180
    needs a new coolant tank? had mine done last week!
  5. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    The cylinder head seal is not... sealing anymore. I have the same issue. I have to change the seal.
    Unless the oil level is up and in this case, the head itself is cracked => a lot of money to fix.
  6. Baza1819
    Baza1819 Member
    254
    Praying its just the Egr cooler tbh !
  7. Baza1819
    Baza1819 Member
    254
    Looking at the egr cooler delete ???
    Not sure what issues this may cause........
  8. Baza1819
    Baza1819 Member
    254
    Bonerp - coolant tank where you pour the water into ? How much did that set you back ?
    The mechanic is thinking egr cooler but he gonna investigate fully next Thursday when the car will be left overnight to dry off, hard to look for leaks etc when the snow is dripping off the car in garage.
    Not white smoke so hoping it ain't head gasket......
  9. Baza1819
    Baza1819 Member
    254
    Only thing I've done up to now is top the coolant up but it seems to have stopped losing fluid ?
    But the heaters are like an asthmatic budgie ( been like that since I bought the car ? )
    It's got my head battered HELP
  10. WilkyA3
    WilkyA3 Active Member
    101
    I believe the sensor in the coolant tank is a common failure, mine flashes coolant every day in the cold, once its warm it goes. worth a try as the sensors part of the tank.
  11. Baza1819
    Baza1819 Member
    254
    Funny enough it's stopped since its warmed up ? Lol
    Ya might be onto something there pal
  12. Turbo jay
    Turbo jay Leather repair specialist
    577
    69
    Yea I also think you might be on to something, mine flashed up for the first time the other day checked coolant and all was fine, sinse it's warmed up It hasn't flashed up again.
  13. Baza1819
    Baza1819 Member
    254
    Wonder how much they are new ?
    Is it just a sensor or the full expansion pot to change ??
  14. WilkyA3
    101
    They're peanuts i believe £13 to my recollection. The sensors part of the header tank so just change the lot. I need to do mine as when it's cold it tells me to check coolant, i do regularly anyways and know its ok.
  15. Baza1819
    Baza1819 Member
    254
    Cheers Wilky😛
  16. infernalzen
    infernalzen New Member
    29
    the coolant sensor prongs
    are notorious for getting coated with something that stops them working properly.
    people have cleaned the sensors +had no more problems.
  17. Baza1819
    Baza1819 Member
    254
    Av topped up fluid, scraped prongs ( which by the way look clean ) and see what happens from there......
  18. robbiedondo
    robbiedondo New Member VCDS Map User
    22
    Had the same on mine, the prongs looked clean but scraped them and fine now
  19. Baza1819
    Baza1819 Member
    254
    Am defo losing fluid, not sure if its to do with prongs causing it spitting fluid out am not sure - goes in audi specialist on Thursday !
    Just wish it was sorted
  20. Baza1819
    Baza1819 Member
    254
    Fixed - happy days
  21. tdisline170
    tdisline170 New Member
    10
    Well what was the issue?
  22. mike foster
    3,967
  23. Baza1819
    Baza1819 Member
    254
    Blockage in coolant system is a cheap guess / check !!
    I had no heat from heaters & coolant light flashing up !
    Checked head / egr cooler & then stripped water timing belt off to check water pump - flush the system sorted it !!
