Coolant flange....
symun Oct 1, 2011
  1. symun
    symun Member
    147
    The one with the temp sender attatched, went to replace mine earlier and i stopped short of starting as soon as i saw the hose clips.
    How are they undone, are they just squeezed with a big pliers.
    Not an emergency as i only leeks a trickle but i would like to do it tomorrow........
    Blanked off the egr instead.....jesus that was effing dirty......
    As soon as i have time the intercooler and hoses are coming off for a good swill........
  2. aragorn
    17,956
    701
    Which hose clips?
    You can undo the constant tension clamps with a pair of water pump pliers, but it can be fiddly.
    Depending on the age you may also have a push fit feed for the heater matrix, these require you to pull up the metal spring, then the hose will pull off with some wiggling.
  3. symun
    symun Member
    147
    Ok cheers.......
