Coolant escaping - 1.8T 190
dope Nov 27, 2012
  1. dope
    dope alcoholic pervert
    199
    Hi.
    I've been loosing a bit of coolant recently. Not loads, but enough to get it sorted.
    Temp stays dead on 90 as it should, and I had a new metal pump a couple of years ago. There's no water in the oil and there's no oil in the water.
    I had a look to see if I could spot where it's getting out and found this
    which is located here
    And I think that looks suspicious.
    My questions are - do you agree? And what is that bit called?
    Thanks!
  2. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Yep thats suspicious, you can see where the G12 coolant has chrystalised to try and prevent the leak.
    I have no idea what the part is called but hoses perish with age so could have split slightly at the end, probably best replacing it.
  3. dope
    199
    Cheers - I'm guessing the number 068 121 101 A on the lower hose is a part number?
    Hard to tell which hose is to blame since it's oozing out of the coupling though...
