coolant blue or red ?
dale86 Jun 23, 2013
  1. dale86
    dale86 Member
    452
    15
    Hi all me and my bro just replaced a nackered coolant pipe on my a4 1.9 tdi and in the garage their was no red coolant left so we just topped it up with the blue can this damage my car ?
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    Audi recommends G12 spec, which is red/pink. I believe problems only occur when two different types are mixed but don't quote me on that. Go spend a tenner on 5 litres of pink stuff and 5 litres of de-ionized water and mix 50-50 for peace of mind. That leaves you another 5 litres of mix for any future coolant issues.
    A quick google suggests mixing different types can form a jelly-like substance so not ideal. Give the system a flush and use OEM recommended.
  3. dale86
    dale86 Member
    452
    15
    Oh dear im gona have to get it sorted then its in for a service in the next couple of weeks so ill get them to flush it then thanks audidoodah should it be ok for a week or so .
  4. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Current stuff is G13 and the best to use.
  5. Audi Doodah
    377
    35
    Should be fine temporarily. Just make sure it gets a proper flush when it's changed.
    Audi have failed to send me an updated user manual with this new spec...same with the oil ;)
  6. AlexGSi2000
    1,464
    199
    Haha, i'm sure you already know, products develop over time! - G12+ & G12++ has been removed from stock at my local dealerships.
    Also - I don't drive the car as intended in the manual, therefore need a different oil!
    The manual also stated to service the car on a long-life schedule - meaning the cams wore out, so I dont take my manual as gospel :)
  7. Audi Doodah
    377
    35
    I'll be careful not to use the 'M' word around you again!!! :wacko:
  8. haytch75
    haytch75 Member
    176
    17
    I've noticed that my coolant has dropped a bit (not much), I'm hoping it's due to warm weather rather than a leak. Anyway I've bought some G13 and wanted to check it's OK to mix with the G12 that's already in there?
    A little more worrying is that my marker float seems to have disappeared. I know it's not essential for operation but I just hope it's not sitting somewhere it shouldn't be and causing a blockage.
    Anyone else lost their float?
  9. dale86
    dale86 Member
    452
    15
    What float lol
