Hi all,
I'm losing around 0.5l every few hundred miles. I've been adding back and no I'm not adding G12 each time!
Had a nose today found a puddle resting at the rear of the engine. The coolant temp sensor all appears to be bone dry so I'm at the conclusion, sadly, that the problem is the rear coolant flange.
http://www.a4mods.com/index.php?page=webcontent/pages/coolantflange.html
However in investigating I removed the PCV valve and then found yellow mustard sludge in the pipe with water sitting on top of it. Are these two issues likely related in some way?
Thanks for any replys!
