Coolant above max level: What adverse effects can this cause?
T3KT0N1K Sep 4, 2013
  1. T3KT0N1K
    T3KT0N1K Member
    104
    9
    I've noticed that my temperature gauge takes, what I believe is an abnormally long time to reach 90. I know what a failed/failing thermostat is like on a 1.8T AUM engine, as suffered one on my old Mk4 Golf GTi and subsequently replaced the stat myself.
    Anyways, after performing a quick visual check of the associated bits n bobs, I've noticed my coolant fluid is above the max fill level. Can this be causing the issue? I know the fluid is hazardous and that the system is pressurised (or at least it should be), so I'm guessing elevated pressure, resulting in cracking or leaks throughout the system could occur, right?
    How should I go about lowering the level? Syphon it out somehow?
  2. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,207
    389
    Noticed my diesel is slow to warm to 90 was warned before i bought it compared to my AUQ Leon.
    Level shouldn't rise, where would the extra come from?
    Syringe to suck some out or a clean rag to soak it up?
  3. T3KT0N1K
    T3KT0N1K Member
    104
    9
    Not a bad idea.
    The only way there could be excess is if someone overfilled the reservoir. That must've happened while the car was in the hands of it's previous owner. I've only had it a couple of months and probably should've spotted it earlier.
  4. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Of course the level should be checked when the coolant is cold.
  5. T3KT0N1K
    T3KT0N1K Member
    104
    9
    Understood. I am well versed in the book of Haynes, having performed a thermostat replacement in the past. :)
  6. fangio
    fangio Well-Known Member
    1,480
    175
    If it doesn't blow coolant out anywhere, forget it!
  7. Bailer
    Bailer Waiting on the Haynes Manual
    24
    Shouldn't make a difference, Can't see anything popping cracking or leaking. There's lots of room in the expansion "ball". It would want to get really really hot. and with additional coolant that might take a fraction longer.
    A lot of Garages/mechanics will fill that just over the max line just to allow for settlement after you've run it for a while.
  8. MouseGB
    MouseGB Member
    54
    12
    Agreed, drain off the excess and check the strength of the antifreeze, keep an eye on it. Just one note, you can compress air but not fluid but even if it over pressurised the valve would open. What would worry me is if there is emulsified oil in the water.
