Cool things to do on a B8 8K VCDS and interior
P77HLP Feb 20, 2014
  1. P77HLP
    P77HLP Member
    75
    Hi Guys,
    just interested to to see what you guys have done!
    Looking into VCDS & wanted to know what cool features you guys have implemented?
    Also interested in any retrofits interior or exterior & European spec or US Spec parts, I.e centre consoles?
    are there any major differences between UK EU & US?
  2. vw754
    vw754 vorsprung Durch Technik
    2,336
    58
    ive fitted footwell lighting all 4 .........and heater vent dial lighting.......oh and here.........Enable Hidden menu in MMI
    Audi A4/S4/A5/S5 B8
    VCDS (VAG-COM) codes
    Enable Hidden menu in MMI 3G
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6
    change 0 to 1
    To access the hidden menu, hold down car and setup together for 5 seconds
    Use this hidden menu at your own risk.
    Enable Hidden menu in MMI 2G
    [07 - Control Head]
    [Adaptation - 10] -> Channel 8 -> Change 0 to 1
    Use this hidden menu at your own risk. Caution: Keep away from the "Bootloader"
    ________________________________________
    Adjust bluetooth microphone sensitivity
    Hidden menu
    Diagnose
    Settings
    Mic sensiblity - choose -6db/0db/+6db
    Change MMI 3G splashscreen...
    Enable through the "hidden menu":
    - navigate to 'car/carcodingvehicle'
    - choose the model of choice in 'configuration line'
    - select 'Update Splashscreen'
    - restart MMI
    Disable After-wipe of windscreen wipers
    [09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
    Bit 3 - Remove check mark (1 = active)
    Disable amber corner lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    Disable Key warning (keyless models)
    [46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 7 set to 0 (Uncheck)
    Disable LED 'wink' on turn signal - pre facelift
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
    Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
    Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
    Disable LED 'wink' on turn signal - facelift
    09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3 (Heading Wink Brightness)
    Default Value is 26, Setting value to 88 (Makes it identical to normal brightness)
    Disable bulb error message with LED reverse lights installed
    CREE LED reverse lights with RESISTOR and I STILL get a bulb out warning?
    Disable "Lights are on" Warning
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
    Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
    Disable NAV & Phone warning messages while entering data at speed
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    Disable Seatbelt Chime
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
    To mute the Soundaktuator
    A9 Structure Borne Sound
    Adaptation 10
    At Channel drop down choose "Volume of structure borne noise actuator" (only choice)
    Enter a value in the proper box (0% = mute )
    Enable Adaptive brake lights
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    Enable Optical rear parking for cars without front parking sensors
    [10 - Park/Steer Assist] [16 - Security Access - 71679] do it [07 - Coding] Byte 0 - Bit 4 change 0 to 1
    Enable Automatic Gear selection shown in DIS
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    Enable Automatic Hill Hold Assist ‘lite’*only works on certain abs modules - see below link*
    [03 - ABS brakes][Security Access - 16] (Enter code presented by program)
    [Coding – 07] -> Long Coding Helper -> Byte 1
    Bit 6 set to 1 to enable hill hold assist.
    AudiEnthusiasts TPMS
    Enable Auxiliary ventilation
    [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
    Bit 1 – Set to 1
    [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    Enable Battery meter *does not appear to work on facelift cars with MMI 3G+ HDD Navigation*
    For MMI equipped cars
    [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
    [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
    Reset MMI
    or
    [56 - Radio] -> Adaption -> Channel 39, add 16 to your value
    For symphony, Chorus and Concert
    Select module 56 - Radio
    Select “Adaptation – 10
    Select channel 39
    Add 16 to the present value
    "test"
    "save"
    “Done, Go Back” and "Close Controller
    Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
    [17 - Instruments] [Adaptation - 10] -> Channel 77
    change 0 to 255
    Enable Double Disarm Beep
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    ensure Module 46, Byte 1, Bit 2 is ticked. This activates the alarm audible notification option
    Enable Drivers Memory Seat
    36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
    Seat memory will be there however greyed out in MMI
    Press and hold down unlock button on key fob for 5 seconds for the windows to come down
    Press and hold down lock button on key fob for 5 seconds for the windows to go back up
    In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
    Enable DRL Selectable via MMI
    [09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
    Bit 5 set to 1
    Enable DRL
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
    Bit 1 = DRL via Front Side markers
    Bit 2 = DRL via High Beams
    Bit 3 = DRL via Fogs
    Bit 4 = DRL via LEDs
    Bit 6 = DRL via Side markers
    Bit 7 = DRL via Tail lights
    Enable Audi Drive Select without the buttons
    By far the best guide is here - AudiEnthusiasts Vag Com
    Enable Euro parking lights that turn on signal at night
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
    Bit 0 - Set to 1
    Enable interior lighting option for pre-facelift
    MMI Basic (Symphony/Concert radio) - (NON-MMI - 2G/3G):
    Code:
    [56 - Radio]
    [Coding - 07] -> Long Coding Helper -> Byte 8 Bit 7 - Interior Light Settings active - (1 = active)
    MMI high (2G):
    Code: Enable the Interior lighting (extended) MMI item:
    [07 - Control Head]
    [Adaptation - 10] -> Channel 1 add 2 to the existing value
    MMI high (2G hidden menu as alternative)
    If you choose to use the 2G hidden menu you will find the setting using the following:
    DIAG SETTINGS -> APK 0x01, 0x0B, 0x0C -> Interior lighting (extended)
    MMI 3G
    This can only be activated through hidden menu
    Enter hidden menu - choose car - choose carmenuoperation - select interior light - set to 5 to allow adjustment whist moving - press return - select cardevicelist - choose interior light and press to fill box in - press return
    Reset MMI (press setup, scroll wheel and top right button next to scroll wheel at the same time)
    Option will show in MMI
    Enable interior lighting for facelift cars
    [09 – Cent. Elect.]
    [Coding - 07] -> [Long Coding Helper] -> Byte 16
    Bit 6 - Interior/Ambience Lighting Adaptation active
    Hidden menu - [carbusassignment] - Interior Light to [CAN Komfort 1/9]"
    Enable fog lamp to come on for the same side as that turn signal
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Check the box or change :Bit 0 set to 1
    Enable Front Turn Signals as Parking lights
    Bit 0- Check the box or change :Bit 0 to 1
    Once the change has been made you can enable the front turn signals as DRL's by making the following change:
    Bit 6 - Check the box or change :Bit 0 set to 1
    Enable Gauge Test/Needle Sweep
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
    Enable Headlights on all the time
    Bit 5 - Check the box or change (Bit 5 Set to 1)
    Enable Import CDs to MMI's HD
    [Hidden menu]
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    Enable Independent Fogs control with high beams
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Enable Lap Timer
    Bit 3 - Check the box for "Lap Timer active"
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    Enable Rear Tail Lights on with DRLs
    Bit 7 - DRL's via Tail Lets Active (1 = Active)
    Enable Release Parking Brake without putting foot on Brake
    [53 - Parking Brake][Security Access - 16] (Enter code presented by program)
    [Adaptation - 10] -> Channel 4 Set to 0
    Enable Release Parking Brake without putting seatbelt
    [Adaptation - 10] -> Channel 7 Set to 0
    Enable Reverse mirror tilt
    [52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
    Bit 3 and Bit 2 set to 1
    Enable Speed through MMI
    [56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
    Does not work if NAV equiped
    Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
    [09-Central Elect]
    [Coding – 07]
    [Long Coding Helper] - Byte 4, Bit 6 = 1
    Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
    [55-Xenon Range]
    [Adaptation – 10]
    [Channel 10] - 0 = Disable 1 = Enable
    Press ‘Test’ and then ‘Save’
    Enables the Headlight Convertor MMI item under the CAR button.
    Restart MMI to see changes.
    Enable TPMS
    * only works with certain ABS modules - see below link *
    Enable Video in motion on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    Set Audi parking system - Switch OFF Speed
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    Set ADS to specific preset Comfort, Auto, Dynamic or Individual
    [09 – Cent. Elect.][Security Access - 16]
    Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
    [Adaptation - 10] -> Channel 64
    [Adaptation - 10] -> Channel 65
    [Adaptation - 10] -> Channel 66
    *Note all four channels needs to be set to the same value.
    Set Headlight washer - Duration
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 6
    change to e.g. 500
    Set Headlight washer - Cycles
    [09 – Cent. Elect.]
    [Security Access - 16] [Adaptation - 10] -> Channel 26
    change to e.g. 10
    Adjust Consumption in DIS
    [17 - Instruments]
    change 100 to xxx (see samples below)
    Sample 1 - Calculation based on volume per distance (e.g. l/100km):
    DIS: 9,3 l/100 km.
    Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
    Channel 3 will be changed from 100 to 105
    Sample 2 - Calculation based on distance per volume (e.g. MPG):
    DIS: 23 MPG.
    Real: 24 MPG. (100 * 23 / 24 = 95,83)
    Channel 3 will be changed from 100 to 96
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 03
    Set between 5 and 100 (5 being lowest and 100 brightest)
    Select language in DIS:
    17 - Instruments
    Byte 8 -> Bit 0-4 - ->
    Select the language.
    Activate SDS for cabriolet:
    5F–Information Electr.
    Change Byte 15 – Bit 0 to 1
    Change Byte 16 – Bit 0 to 0
    Change fuel-tank charisterics:
    17 - Instruments
    Adaption - change channels 30 and 33
    To increase radio play time after car is turned off:
    In the Hidden Menu:
    MMI 2G:
    "MMI->SETTINGS->Standby Timer" - will allow you to hear e.g. Radio or CD longer before MMI shutdown (if ignition is OFF) - default 10 min. and the max. is 60 min.
    MMI 3G:
    From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes.
  3. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,673
    2,571
    I have turned a few things on in my car. Have a look at my build thread.
    Karl.
    kev.s likes this.
  4. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group TDi saloon
    3,011
    766
    Great guide! Thanks! Do you have pics of the heater lighting working?
  5. jamin128
    jamin128 Member
    208
    Evening, how did you retrofit heater/vent lights?
    Ben
  6. vw754
    2,336
    58
    buy the lights from audi,then a bit of a mission realy
  7. Anthony566
    Anthony566 Active Member
    732
    111
    43
    When you say buy the parts what do you mean is that bulbs and holders and cable ?
  8. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,472
    718
    Anybody know if there is a coding to disable the driver door chime when it is open and the engine is on?
    ....or was it key in ignition and driver door open, the car beeps like crazy.
  9. dieseldoos
    dieseldoos Active Member VCDS Map User
    206
    96
    Just press the button on the wiper stalk to turn it off.
  10. Liquidfusion-S3
    1,472
    718
    Thanks, but was looking to see if anyone figured out a permanent solution
  11. Anthony566
    732
    111
    43
    Is it controlled by one of these two ??
    Disable Key warning
  12. vw754
    2,336
    58
    anybody know if i can code my foglamps,so they dont give bulb out warning?
  13. benjie
    benjie Well-Known Member
    1,223
    305
    Well done that man! I didn't realise you could do that.
  14. antowens
    antowens Car Nut Regional Rep
    845
    275
    What do you mean by heater vent dial lighting mate ?
  15. Anthony566
    732
    111
    43
    The wheels that you move to open and close the dash vents have lighting behind then if you have the lighting fitted at factory.
    antowens likes this.
  16. T0m
    T0m Active Member
    516
    26
    Hey Anthony dont suppose you have a how to on the heater vent lighting do you?
  17. benjie
    1,223
    305
  18. Mark Fryer
    Mark Fryer New Member
    Hey all, just picked up my new S4 Avant (Daytona grey black edition). Could anyone tell me if there is a way to activate keyless entry? I opted not to have the tech pack (Nav) and convenience pack but wondering if its on there but just not activated?
    Mark
  19. dpaz
    dpaz Active Member Team Tango
    526
    115
    43
    You would know if you had keyless entry (advanced key).
  20. razza1
    razza1 Well-Known Member
    3,075
    829
    Comes with the start button by the gearstick...
  21. benjie
    1,223
    305
    And there's no way to activate it without some quite involved modification.
  22. Mark Fryer
    Thanks for the replies. Pretty much as I thought, but worth an ask! :)
    jphc likes this.
  23. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    390
    Advance key is a factory fit only.........unless you want to put in a lot of work and replace looms etc.
    Although, I have it and it was on my "must have" list as had it on the last car too and its fantastic, although I must say its better on BMW.
    Audi Advance key covers:
    Key stays in pocket and doors unlocked by grabbing the handle.
    Seat and wing mirror location are set automatically
    BMW comfort key covers:
    Key stays in pocket and doors unlock by grabbing the door handle.
    Seat, wing mirror and stearing comlum are set automatically.
    diff key also remmbers induvidual AC settings, satnav customisation, audio customisation (diff key - diff bass/trebble and equaliser settings), last sourc used etc.
    The BMW stores all that info to each key, even exterior light settings, its veyr good.
    Both versions are great if two or more people are using the car.
  24. kev.s
    kev.s Active Member
    226
    93
    cracking build thread, like some of the features added, got a pic of the vent lights?
    fair bit of graft there to complete the build, good job.
  25. Scott.T
    Scott.T Well-Known Member
    739
    279
    Anyone know the security code on a B8.5 facelift for the Parking Brake menu.
    I want to turn off the Seatbelt recognition for releasing the parking brake.
    Its a pain to have to clip the belt in just to move the car up the drive
    GeoffDunk likes this.
  26. benjie
    1,223
    305
    Can you put your foot on the brake, then press the handbrake button to release the parking brake? I can in mine but they may have changed it from B8-8.5.
    Try this:
    [53 - Parking Brake][Security Access - 16] (Enter code shown by VCDS)
    Remember what value channel 4 was before you change it so that if it doesn't work, you can put it back to standard.
  27. Scott.T
    739
    279
    I can use the footbrake but my drive is on a hill with the nose of the car close to the garage door. Therefore doing the footbrake/accelerator shuffle is a bit risky.
    I have tried the above VCDS menu's but the code presented by VCDS does not unlock the security access. Therefore I assume this is a B8.5 difference.
    What codes have you ??
  28. Scott.T
    739
    279
    Goggle is your friend :
    [53 - Parking Brake][Security Access - 16] (Enter code shown by VCDS or 78713 for B8.5 Facelift)
    Then select the option to disable seatbelt recognition
    I also switched to Manual Release rather Manual with Footbrake.
  29. benjie
    1,223
    305
    There we go then, easy. The coding I posted worked for me as I have a B8. So much more convenient to be able to just press the button!
    Scott.T likes this.
  30. chucky1
    chucky1 Well-Known Member
    559
    370
    Hey Liquidfusion, did you figure this one out as a permanent solution?
  31. Liquidfusion-S3
    1,472
    718
    Sorry I never got around to looking into it, although I remember someone saying you have to press the right button to turn off the sound when the door is open
    No chance of looking at it anymore, I've turned to the dark side - S3 :)
    scotty76 likes this.
  32. chucky1
    559
    370
    Thanks Liquidfusion. Yes, you press the wiper stalk button. Still looking for the permanent switch off. I have not been able to find the VCDS reference for this function.
  33. humkar
    humkar Member
    Geoff,
    I have advanced key in my B8.5 A4 BE. How can i set different seat positions? I haven't figured that out. I had heard it had this ability but thought it is only available in US of AYYY.
    Thanks bud..
  34. maarko007
    maarko007 New Member
    hallo, i was trying to tunr on d and s driving mode, but wen i go on chanel 63 it say to me error not awailable, can i somehow that fix?
