Convertable rear light options?
leegsi Sep 21, 2013
  1. leegsi
    leegsi Active Member
    489
    57
    What rear light options are there for the convertible?
  2. quattrojames
    14,050
    573
    Most people fit B7 rear lights.
  3. vr6gordy
    vr6gordy Well-Known Member
    2,755
    176
    you could put the b7 cabbie lights in but you need convertors for the loom
  4. Andy27168
    Andy27168 Member
    130
    9
    Are they just plug and play with the adapter looms or is a bit of coding on VCDS needed as well?
  5. hades-
    9,480
    646
    yes plug and play
    there is codeing but they will work without
  6. leegsi
    489
    57
    When you say 'adapter looms' is that the part that plugs into the lights between the car loom (The standard loom for the B7)?
    Also what would the coding do different?
  7. quattrojames
    14,050
    573
    Kufatec sell the looms I think.
    Have a look for some posts by 1wheelonly who was up to speed on his Cab's, I think the coding is needed to swap the brake/fog lights around or similar.
  8. hades-
    9,480
    646
  9. leegsi
    489
    57
    Thats a lot of money for a few connectors and a bit of wire.
  10. hades-
    9,480
    646
    you have 2 choices
    buy one
    make one.
  11. hades-
    9,480
    646
    the lights aint cheap either
  12. leegsi
    489
    57
    If I knew what wires went where I would lol
  13. VagCabby
    VagCabby Active Member
    513
    76
    Easy to make your original loom fit the b7 rears costing £0. If you get the b7 looms with your new lights. Cut the tail light off your b6 loom and then solder the 501 tail light from the b7 loom onto your b6 loom. Then all the holders fit into the b7 light fine apart from one which needs a 1 mm slit cut into the plastic on the light hole of the b7 light. Then all you need to do is either tape up the 2nd reverse and fog lights and tuck behind the light(I had it like this for 6 months) or cut the holders off and fit a resister (I have now done this) then you just nneedto code the top tail light out with vcds. Lights are expensive if your inpatient, I looked on ebay every day for 3 months and ended up paying £20 for one light and loom and £25 for the other light and loom.
    Tobester likes this.
  14. leegsi
    489
    57
    In no rush so see what comes along.
    Any chance of a picture and the resistors you used please showing where everything went for future reference?
