Conversion from pre-facelift double grill bumper to facelift S-line bumper
mattandrew Apr 24, 2008
  1. Khufu
    Khufu Well-Known Member
    5,704
    31
    It really makes a difference. Here's my A3 with S3 bumper at the campsite at the foot of Ben Nevis
  2. ru4shaw
    ru4shaw Member
    222
    will the s3 bumper go straight onto 04 plate
  3. Ash B
    Ash B Well-Known Member
    5,831
    Yes the S3 bumper will but same as the S-line will need a new bonnet but with this will need to trim the reinforcement bar on the edge so the bumper can fit on. Only a few cm i believe
    Ashley
  4. Khufu
    5,704
    31
    yes its the same job as fitting s-line except costs more LOL. For the S3 bumper, as Ash says, you need to trim the lower edges of the reinforcement bar to clear the larger foglight cutouts of the bumper. I marked & used an angle grinder LOL
  5. Hellz
    Hellz Geordie Racer
    378
    If I already have a pre-facelift S-Line do I still need to buy the fogs if I go with:
    A. The S-Line facelift bumper
    or
    B. The S3 bumper
    Also, is the Side impact reinforcement/carrier (8P0807113B) needed for all conversions? It's just I havent seen this particular part mentioned before... not too keen on the idea of angle grinding parts down! :p
  6. Ash B
    5,831
    Would need new fog lights surround im guessing due to its change when we had the face lift and the S3 fog light surrounds different to the A3 design anyway. Not 100% sure you need to change the fog lights might still be the same size with the S-lines. But im sure some one will correct me now.
    No you dont need to change the reinforcement bar really, just some people change it as they dont want to cut, sand or grind down the edges :)
    Ashley
  7. heliflyer
    heliflyer Member
    149
    Hi mate the fog surrounds and fogs have to be changed there different fogs, and the surrounds are quit a bit bigger that pre facelift slines as i had to do mine i also bought the new reinforfment bar but as mine was a s line they were the same on some models they differ and you either have to grind them of fit new for 50 quid its a no brainer ( idea for classifieds sell reinforcer) cheers Ian
  8. mike1628
    mike1628 Member
    125
    Hello All
    Benskin, you live the closest to me as im in Bristol and wondered if you could be my mentor lol.
    I've got a lava grey 04 3dr and im saving up for the parts at the mo when get them all
    can i call on you.
    Cheers Mike
  9. Ash B
    5,831
    Mike more than welcome mate! Lol Same colour as me good choice:arco:
    Yes more than welcome to give me a call, still in the middle of doing mine, if you need parts fitted can get my uncle or friend to do it quite cheap. As they will be doing mine with no choice :) I'm just waiting to get mine painted as i dont have much any at the moment pay day soon though :). Drop me a PM and i'll send you my number.
  10. mike1628
    mike1628 Member
    125
    Nice one pm'd
  11. MattyV5
    MattyV5 Member
    135
    Could I keep that in mind too? (im in Weston-super-mare)
  12. Ash B
    5,831
    Yeah mate thats fine. Weston-super-mare not that far from me either.
    Ashley
  13. MattyV5
    MattyV5 Member
    135
    Thank you. I'll probably never be able to afford it, but thanks. :friends:
  14. Ash B
    5,831
    Thats fine mate, what you going for s-line upgrade or s3?
  15. MattyV5
    MattyV5 Member
    135
    Probably just an early single grille bumper but I need Washer holes in it. I also heard the earlier bumpers should be compatible with the the double grille fogs? I would then just get the bump strips smoothed over.
    There is one on Ebay for £130, but would rather pay Under £100 as I'll also need the bonnet, and get them sprayed up!
    Need to get some new wheels on first though and get it lowered a little.
  16. Hellz
    Hellz Geordie Racer
    378
    Are all of the facelift (2005-2008) bonnets the same?
    For instance, if i bought the S3 bumper and grille would I also need to source a bonnet specific to the S3 or would any of the facelift bonnets fit?
  17. Lee_R
    Lee_R Active Member
    2,499
    12
    Correct! There are 3 bonnets
    2003-2005 (no sportbacks with this bonnet)
    2005-2008
    2009 onwards
  18. MattyV5
    MattyV5 Member
    135
    Hi,
    Does the 3dr facelift Sline lower rear bumper bit fit a pre-facelift 3dr?
    i.e are the rear bumpers the same on a pre-facelift and facelift models?
  19. Lee_R
    Lee_R Active Member
    2,499
    12
    The bumpers are different (No trim on the facelift S line, its all smooth) The valance is not a direct fit to the earlier bumper but it has been done with some minor mods.
  20. MattyV5
    MattyV5 Member
    135
    Ok, thanks for that. I would replace it all but I have rear p.sensors and don't want to start messing about with them!
  21. MattyV5
    MattyV5 Member
    135
    I have the Bumper! I got a non sline facelift bumper with washer holes on ebay for £90 delivered. Not too bad. I went for the non sline bumper jut to try and make it as easy as poss!!! Just got to get to get the grill now. Should be no more than £50?
    With regards to the bonnet, could i just get a bodyshop to weld 2 plates in to make it line up with the bumper?
  22. Khufu
    5,704
    31
    To do it properly & then match the paint up could cost you more than the bonnet. The bonnet is so noticable on a car it would have to be perfect. IIRC, my bonnet was £158+vat new from Audi.
  23. jb111s
    jb111s Member
    139
    Agreed. Just buy a new bonnet. The lines on the bonnet are also different so it matches the different width of the new grill. I couldn't find a bonnet either, so ended up buying through audi.
    I've just finally finished my a3 sport full s-line conversion. Now have the facelifted front-end, s-line spoiler & complete s-line trim inside (including headlining), wheels, suspension etc.
    It looks so much better. Ebay is your friend for all things s-line.
  24. Hellz
    Hellz Geordie Racer
    378
    Does anyone know if the fog lamps on the facelift A3's (2005-2008) are the same fitment across the range?
    For example - I'm just about to buy an S-Line bumper and I'm able to get the fog lamps from a facelifted sportback A3 or a standard 3dr A3.
    Will the fog lamps from the sportback/standard 3dr A3's fit OK with the 3dr Sline bumper?
    Thanks in advance y'all
  25. Bailey
    Bailey Member
    247
    15
    I think i am going to go ahead with the conversion in the near future. it looks to much better with the single grille rather than the split ones
  26. hc_TK
    hc_TK New Member
    is there someone that can get me the the parts i need to upgrade my 2004 (dualframe) to 2006 singleframe s-line or s3 front. The best is if the parts could be painted lavagrey and shipped to norway. these parts are hard to get!
    Send me a pm and we can talk price ;)
  27. MattyV5
    MattyV5 Member
    135
    Was this pic before or after it was lowered on the eibachs? (before I hope?)
    Matty
  28. C43guru_43
    C43guru_43 New Member
    Hi can anyone pm as how and who can do the whole conversion to the big single grille! Thanks
  29. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    The how is in this thread mate!
  30. steven lambie
    steven lambie New Member
    hi, i am just new to this site. i seen that you have done the s line facelift, i have a 53 plate a3, is it possible to do the facelift with this car? tanks
  31. Staz
    6,206
    64
    Yes it's possible. The info is in this thread.
  32. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    As leon has said all the info is in this thread
  33. Ash B
    5,831
    :think:
  34. Tommy
    Tommy Makinen...ha
    447
    Whats wrong ash?
    You still confused abouts grills?
  35. Ash B
    5,831
    Lol nothing wrong mate:icon_thumright:. Was just thinking about the last two questions asked in this thread. Made me laugh:laugh: As the answers are all over this thread! :happy:
  36. pdargan22
    pdargan22 New Member
    25
    Hi guys, im thinking about doing this conversion but im unsure if i need the reinforcement bar? Can anyone confirm if i do or not? My car is an 04 1.6 3dr
  37. Ash B
    5,831
    If your doing an s-line conversion you wont need to. Only if your doing an S3 conversion.
    Good luck
  38. dino123
    dino123 New Member
  39. mattandrew
    977
    21
    Its one of the old facelift bumpers, its not a sline, its not got fog grills, Its got the horrible rub strips in the bumper
  40. slyesco
    slyesco New Member
    21
    Ok. So I'm looking to do a conversion. I have a 05 preface lift 2.0 fsi. I live in Croydon Surrey and am looking for parts and someone to this for me at a reasonable price. I'm open to both s-line or S3 bumpers.
    Thanks!!!!
