Control Arm sets
B5NUT Jun 25, 2010
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,760
    660
    I'm looking for a complete control arm set, for a A4 a saloon 1.8 ADR. I had a quick search on ebay but I can only find the junk that fails after a few months. I was look for Lemförder or meyle kits can anyone point me in the right direction, as I can only find individual items.
  2. neilA4
    neilA4 Member
    211
  3. aragorn
    18,434
    843
    or get a meyle kit from german ebay
  4. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Just got a set from Allgermanparts. Asked for the metal S4 rod ends instead of the plastic items that come with the kit. Was an extra £30. In all cost me just over £400 heads. I'm fitting them tomorrow, (pinch bolts aside-I fitted new ones a few months back fitting new springs after the epic I had with the old ones) is there anything I should know when fitting them? I'm getting the car alligned afterwards too.
  5. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    start plusgassing them or soaking them in WD40 now. makes life so much easier for tomorrow
  6. AndyMac
    9,832
    46
    Make sure you have a few 17mm & 18mm spanners & sockets.
    Have you got the step by step guide off AudiWorld - very useful.
  7. phoenixv6quattro
    1,396
    Thanks gents! Someone told me a while back that you have to tighten them with the car ob the floor (wheel on the floor??!!) I'm going to be using axle stands/jack so hows this/whats the best way to get this done?
  8. Jonion
    Jonion Member
    193
    As they are rubber bushes you do need them to be that way or they will sit out of their normal position and cause premature wear.
    Easiest way is to jack under the hub to raise the suspension/knuckle etc. .to it's normal position and tighten them.
    Or jack it until it just starts to take the weight off the axle stand.
  9. Jp-tqs
    Jp-tqs Member
    183
    How long does it take to replace all the control arms in the kit in one go?
  10. Spacecowboy
    Spacecowboy Member
    367
    Where would I find the guide?
  11. phoenixv6quattro
    1,396
    uhhhh .... Audiworld.....
  12. AndyMac
    9,832
    46
    The second time I did it it took me 7 hours to do both sides. The first time took 2 days as the pinch bolt had welded itself to the carrier on the passenger side.
    The guide is here:
    http://freepdfhosting.com/afb83a1221.pdf
  13. voteforpedro
    voteforpedro Member
    632
    Took me about 2 weeks. :p
    Avoid the cheap eBay ones at all cost... 5k miles (if that) and one of them is already knocking.
  14. Spacecowboy
    Spacecowboy Member
    367
    Thanks Andy
  15. AndyMac
    9,832
    46
    Yep, been there done that, which is why I bought my Meyle kit from allgerman as I refuse to give any more money to bloody autoteile rippoff merchant
