CONTEST: Best CAI for S3 8P - Post your own!
AJames Jul 29, 2009
  1. AJames
    AJames Rally Driver - road Audi S3-8P
    115
    Hello to all,
    I have been trying all the best CAI's on the market, and haven't found anything that really was spot on. From here, I used my engineering and rally mechanic's help to come up with something bespoke, a setup that gave us better performance and lower noise than the monster conical filters, such as the Evo MS.
    Here our output, please post your own, so we can make this a clean and propositive discussion on how to get the best from our beasts!
    Cheers,
    AJ
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    There are plenty of threads with people's opinions on their CAIs mate.
  3. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    im getting a nuespeed cai for 95 quid it has a cone filter to , bargain though and i hope it sounds like a twister...
    yours looks a bit of a moster whats the drum at the top , i also heard carbonio intake wasnt very good gains is that what you have at the bottom ??
    also make your picture smaller mate its massive and taking ages to load because of the file size ...
  4. gixxer600k4
    gixxer600k4 Member
    692
    yea that is true what u have heard about carbonio. you will get a gain but it will be tiny, carbonio mainly aim for producing a good quality, well built design. they do look gorgeous but the filter isn't the best. DBilas, evoms and the BMC CDA are all worth a look, pipercross also do a good cold air induction kit. but i think the one that will be up and coming is the forge twin take, there is a massive thread about it on ASN
    i have heard that K'n'N aren't that good as the filter contains oil which clog up the MAF but im not too sure about that because surely K'n'N have so much money and racing technology that they know what to do and how to make a filter that works.
  5. Spin140
    Spin140 Well-Known Member
    2,196
    186
    I think with K&N you can opt for either dry or oiled, no problems so far with the Evoms on my car and I have grown to love the sound it makes, IMO the most ideal solution would be an Evoms type set up but with an enclosed filter so this one looks pretty good.
  6. AJames
    115
    The 'thing' you see at the top is a BMC CDA venturi effect air filter.
    The part in the lower right side is the Carbonio conveyor.
    The upper bend, with MAF sensor, is genuine Evo Ms.
    The modest gains given by the Carbonio's full solution are true, due to the fact that they use the original air box and ducting, just applying the conveyor and a better filter.
    The Evo MS is noisy, yes, but also provides limitations in air when going fast on motorways, because it does not have a direct air feed. They have created a chamber, that, ultimately goes in atmospheric depression, and makes you loose power. The only air you get, is from half of the standard front side ducting.
    The Forge CAI is much less effective than the EVO MS, tried.
    We have them all, and tested them all.
    Sorry for the large picture, I did not have the time to fiddle around.
  7. gixxer600k4
    gixxer600k4 Member
    692
    so the carbonio conveyor you have, that doesn't house the filter, the filter you have is the 'thing' at the back which i take isn't the standard element as you say it is the venturi air filter, or can you request that to be in the CDA from BMC
  8. KeepItTidy
    KeepItTidy Member
    88
    Thats not good to hear :unsure:
    Im looking at Putting in Forge CAI very shortly.
    When you say much less effective, is evo MS by FAR the best on the market? Then second is Forge? What did you find with the forge intake? any power readings?
    Im going to install a CAI ; 76mm Downpipe (not whole exhaust),Stage 2 software.
    Hoping that will give me the power im looking for!
    Any tips/advice? ;)
    P.S your ride is awesome!!! well done bud. Wish I had your budget :blush:
  9. 10blazin
    3,301
    yeah james put some pics up of your car id like to see it sounds awesome on your sig ??
    what bhp you running ...
  10. AJames
    115
    No power readings for the moment, we are working on the remaps.
    The EVO MS is the best power, bolt-on, CAI money can buy.
    The Forge system (I do have a high reputation of Forge), did not give the same power of the EVO Ms.
    All the CAI's have been tried on a valet S3 at Superchips, on their rolling road.
    The CAI I built gives you the best of all worlds, and more power, whilst still beeing as silent as the standard parts.
    For your power projects, my advice is, in the following order:
    - Autotech internal components for your fuel pump;
    - Full Milltek, resonated;
    - CAI (mate, try to replicate mine, can give you specs)
    - REVO remap 2+
    - DV.
    I have installed a Forge Twincooler intercooler system but, there actually is no real need for it till you go to a bigger turbo compressor, or if you really drive dead hard in the hot, like me, here in Italy.
    Hope this helps
  11. AJames
    115
    Thank you mate, much appreciated. Am aiming to reach 360bhp, still working on electronics...
    Here a couple of pictures, also some from the trackday in Monza, last Saturday the 11th.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  12. KeepItTidy
    KeepItTidy Member
    88
    Thanks for advice! :yes:
    Im still new to the modding game, this is my first car I'm modding.still
    trying to learn as much as possible :happy:
    Unfortunately doing all those mods are out of my buget for now :ermm: . Gona try do the mods in 2 stages.
    Either I can go
    CAI,Down-pipe,stage 2 software .. and leave the full zorts and HPFP for a much later time.
    OR (now as per your suggestions)
    CAI,Down-pipe,HPFP and leave the current stage 1 APR software on
    only go stage 2 software MUCH later when I get the zorst.
    :wacko::confused:
    the DV is way way down the line atm unfortunatly :( Parts are just to expenive here in SA with the exchage and shipping :(. dont you have an extra Fuel pump and DV lying around by any chance :p
  13. AJames
    115
    Mate, I understand budget problems, don't worry. Unfortunnately I don't have anything useful lying around here...
    My suggestion is to go by full steps:
    - If you but the exhaust, get the whole thing, not only a downpipe.
    - Then buy the Autotech pump internals.
    - Then buy a CAI
    - Then remap at REVO with stage 2 or 2+
  14. 10blazin
    3,301
    nice car james lovely colour , love the set up to i dont have them sort of funds lol .. just stage one and a cai for me at the mo my damn insurance is 270 a month its ridiculas gona sort it soon so i can have more doe for mods....
  15. AJames
    115
    Thank you mate, I also pinch myself to see if it's true at times!
    Just a lot of experience in race cars got me to know what I want and how it works.
    Cheerios.:s3addict:
  16. gixxer600k4
    gixxer600k4 Member
    692
    are you able to buy the BMC CDA but request the venturi filter to be inside, or do you have to do a bit of modifying?
  17. AJames
    115
    No mate, the CDA itself is a venturi-effect filter, it is all inside the box, as you buy it.
  18. gixxer600k4
    gixxer600k4 Member
    692
    o right, i always thought it was a plain filter, is the venturi filter much different than any normal filter like the K'n'N 57i
  19. Spin140
    2,196
    186
    I think Mr James should start fabricating these and sell them to us Forum Guys !!
  20. AJames
    115
    It is an idea mate, but they would be really expensive. I should have a look in to how much I spent in building it.
    We could consider making a poll on this?!?:s3addict:
