connecting the phone thingymajig
kev.s Mar 20, 2012
  1. kev.s
    kev.s Active Member
    226
    93
    anyone know how much it is to connect/install the phone into the radio bit of the car? i press the "tel" button and it says not installed.
    oh, new to the forum,new to audi,and sh1t with technology :icon_thumright:
    cheers in advance
  2. xs2man
    xs2man Member
    792
    Are you talking about Bluetooth? Make sure your bluetooth is switched on on the phone, and discoverable, then you probably need a passcode or something? Which you enter into both the phone and the car IIRC.
  3. kev.s
    kev.s Active Member
    226
    93
    no i don't think so, on the radio display it has "Tel" and the steeing wheel has a button with what appears to be a voice icon, when i push either of these it comes up not installed, don't think this is bluetooth , is it?
  4. xs2man
    xs2man Member
    792
    You have to connect your mobile via bluetooth to the car first though.
  5. kev.s
    kev.s Active Member
    226
    93
    ah ok, so does this then allow me to use the steering wheel function and radio facia to make/receive calls using the speaker system in the car?
  6. xs2man
    xs2man Member
    792
    Yeah. Its just a built in hands free option. So you make and receive calls through the car stereo rather than through the handset.
  7. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Do you have the owners manual?
  8. kev.s
    kev.s Active Member
    226
    93
    i do an i've tried looking for details about this but can't see anything. i tried to find the system via my phone and it showed SOMETHING CALLED BLUE&ME, i tried to connect but then it disappeared and i can't find it anywhere now :(
    it's a 58 s-line and wondered if this should be standard or would it be an optional? my mate's 09 had it but unsure if this was a standard feature.
    sorry for the questions, and thanks for the advice all.
  9. scoTTy
    scoTTy Active Member
    1,962
  10. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    just out of interest, do you have an adapter in the centre arm rest or a sharkfin on the roof?
  11. kev.s
    kev.s Active Member
    226
    93
    got an aux in the arm rest, no shark fin.
    fecked off with it now, gonna go the dealer the morro :/
  12. xs2man
    xs2man Member
    792
    Hit the TEL button on the stereo, and goto bluetooth PIN. Enter 0000 or something. Then go to your phone, and connect a new bluetooth device. Search and your Audi bluetooth will come up. Connect to it, and when it asks for your passcode, enter the one you entered earlier. Job done.
    As for making and receiving calls, its easily done thought menu system, or you can read the manual and it will tell you how to do it by voice.
  13. Soot1e
    Soot1e Active Member Team Navarra Audi S4 Audi Avant Owner Group
    173
    39
    If when you press the phone button and you are getting "telephone not installed" you do not have Bluetooth fitted. You can try all you like searching from your phone but it will not find what is not there. Retrofitting oem kit is very expensive, parrot devices may be your best bet or other solutions as will no doubt be recommended on here.
  14. kev.s
    kev.s Active Member
    226
    93
    perfect, thanks for that. :( i'll see how much dealer will charge to hook up oem kit. failing that i'll just let the bu66er ring!
  15. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Retro fitting oem bluetooth is not that expensive I did it the unit is about £230 plus an hours fitting, audi will charge you alot more
    If you want more details let me know.
