Condensation?
A4Steve Jan 20, 2003
  1. A4Steve
    A4Steve Guest
    Just lately I have been getting a lot of condensation on the inside of the A3 - to the point were I had ice on the inside when it was really cold a couple of weeks back. I have spoke to the garage and they suggested it could be the air-con until I told them that I didn't have air-con.
    There are no obviously leaks (when there is heavy rain there are no damp patches on the inside).
    Is this just a common problem with A3s?
    Any help appreciated.
    Ivan
  2. amoffat
    amoffat Member
    466
    I have heard that cars with air/con leaks and problems sometimes get this?
  3. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,739
    197
    It could be a number of things as mentioned above. First thing I'd check is: are any of your carpets wet or damp. Is there any water in your spare wheel well?
    If its not any of those, it could be you pollen filter. Air-con and non-air-con cars have them. If they get moisture in them, it gets released into the car as soon as you switch your fans on. Also, make sure your air-recirculation button isn't perminantley on - that can cause things to steam up pretty quick in a non air-con car.
    Just some ideas.
    AL
  4. gtdog
    gtdog Member
    194
    I had a very similar problem with my old A4.
    It transpired that the heater matrix had a slight leak.
    Sadly expensive to fix, and a bu***r to live with.
    Best of luck /ubbthreads/images/graemlins/grin.gif
