Condensation problem
Quattro180 Jan 3, 2011
  1. Quattro180
    Quattro180 Member
    99
    The car seems to have alot of condensation on the inside at the minute? Is this normal because of the cold snap or could there be a problem?
  2. hades-
    9,481
    646
    check your pass foot well
    the drain under the batt may be blocked
    very comon
  3. yendall24
    yendall24 Member
    571
    hi mate have you checked your carpets for any wet patches usualy in the footwells also check the bulkhead where the battery lives if the drain holes are blocked this area can flood and over spill into the cars interior through the pollen filter housing also is your rear screen wash still working if not the fluid pipe could of come off dispensing the washer fluid directly in the rear hatch
  4. Quattro180
    Quattro180 Member
    99
    Will check it now, cheers
  5. Quattro180
    Quattro180 Member
    99
    i have hust checked the front carpets and they seem dry so i checked the rear tailgate and the washer fluid is leaking into the boot. Another job on the list for next weekend!!!
  6. A4 nut
    A4 nut Member
    351
    A knackerd pollen filter will condensate your car up try replacing that.
