Condensation on inside windscreen
coolguy Jan 19, 2014
  1. Gazwould
    Gazwould Well-Known Member
    5,136
    2,097
    All this is simple physics.
    Car interior a higher temp or humidity to outside.
    This warm air condensates on the coldest object, the glass.
  2. coolguy
    coolguy Member
    144
    19
    That's what I was thinking, I reported this problem a few months ago, they checked it out but said it was normal/part of the design.
    Will mention it again to them next week when my car goes in.
  3. h5djr
    9,429
    1,749
    Basically the same as a building, except most buildings these days have double glazing. Ventilation is the biggest cure for condensation in building and I suppose the same is true for cars.
    The full demising setting show normally only be used for a short while and then, as the Owner's Manual says "To prevent the front side windows from misting up in wet weather, we recommend opening the side air outlets, pointing them to the side and selecting the 'spot' setting"
  4. luadr1
    luadr1 New Member
    19
    Yes and it's applied neat
  5. Gazwould
    5,136
    2,097
    :cool:
    I'm going to conduct an experiment.
  6. luadr1
    luadr1 New Member
    19
    any feedback'
  7. Gazwould
    5,136
    2,097
    Not yet as the same almost daily climatical conditions haven't repeated themselves.
    I have been using a Bluecol anti mist which is supposed to eliminate interior condensation, well it's usually dripping wet so I think it's a chocolate tea pot unlike their rain repellent which is superb.
    I coated the inside windscreen with the useless Bluecol then did a thin vertical of neat washing up liquid.
    I can see potentially why it would work as it is slimey, scuba divers spit into their mask and using a finger spread and rub it over the inside area, then a quick rinse.
    It works and this applies to swimming goggles too.
    I'll report back my findings at a later date.
  8. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,688
    526
    I have the most wonderful image in my head of your windscreen covered in all kinds of gunge and slime now! lol
    JohnM100 likes this.
  9. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    952
    394
    Ditto. Reminds me of the Friends episode with Ross and the leather trousers....
    Gazwould - respect to you for taking one for the team!
    John.
  10. Gazwould
    5,136
    2,097
    Practically if the washing up liquid didn't work I was going to employ the local pikeys with strong cheap cider and cigarettes to gob on the inside of my windscreen. :scared2:
    BGS likes this.
  11. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,046
    1,783
    I have no idea what you guys are referring to but I wouldn't let washing up liquid anywhere near the inside, or outside, of my car. It contains salt and could ruin the trims...
  12. 0B1001001
    0B1001001 Well-Known Member Team Monsoon Audi S3
    451
    278
    Naw, use toothpaste before use, no spitting please! Clean the silicone from the new mask and then leave well alone. Not that I'm suggesting you use toothpaste on your windscreen... :think:
  13. Gazwould
    5,136
    2,097
    Toothpaste before 1st use of a mask yes.
    Are you a scuba diver ?
  14. 0B1001001
    451
    278
    Yeah but not for a while - mostly snorkelling and swimming now.
  15. Gazwould
    5,136
    2,097
    BSAC or PADI qualified ?
  16. Flugel Hound
    Flugel Hound Member
    89
    40
    I see signs of moisture run/trails down the inside of my screen.
    My car lives outside at all times and never use the aircon plus have sometimes had wet clothing in the car.
    So from reading the above im a prime candidate. Will give it a clean and use aircon more.
  17. coolguy
    coolguy Member
    144
    19
    Well just been back from the garage and Audi have found nothing wrong. Just told me to keep and eye on the problem and if it happens a lot more/serious, they will book it in for a few days for observation.
    Oh well...
  18. PilotAudi
    PilotAudi New Member
    2,352
    479
    Why don't you use aircon. It should be used on a regular basis or you will have problems .
  19. Joetidman
    Joetidman Well-Known Member
    1,062
    563
    I agree with pilot here, aircon is designed to be used all the time now, when not actually cooling air the compressor acts as demist. I've used it permanently in my scirocco with minimal impact on fluids and mpg
    h5djr, cemerson and PilotAudi like this.
  20. cuke2u
    6,046
    1,783
    Yes leave it on, if you don't then the seals inside the AC will fail after a while. It is designed to stay on all of time anyway...
    cemerson likes this.
  21. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,568
    1,171
    I have my aircon on all the time too. I've tried a few journeys with it off but haven't noticed any effect on my mpg.
  22. Gazwould
    5,136
    2,097
    It works,
    a definate clear line where the washing up liquid was applied and buffed off.
    mjcourtney likes this.
  23. hopeless
    hopeless Member
    56
    14
    Aircon is not really designed to be on all the time but they are very reliable nowdays so keeping them on all the time shouldnt give too many longevity issues.
    In fact not using the aircon at all is more damaging on the unit because the aircon gas/fluid contains a lubricant for the compressor and this needs to be circulated regularly or the unit seizes.
    Oh and yes, it will affect the mpg, its a compressor being driven from a belt connected to your crank so its bound to sap some power.
    To reduce condensation you could try some Bob Heath or similar visor/windscreen anti fog spray. Work great for motorbike helmet visors, I used to use it all the time.
  24. bobbinz
    bobbinz Flat out ......in neutral
    15
    Just to add a bit more confusion into the mix, I've got the steamed up glass too, however my A4 B6 Avant also has condensation on the metal inner skin of the roof above the head lining. And it's not as a result of sunroof drain issues, I don't have one. (Sunroof that is!)
    My air con is suspect, but I can normally 'free' things off (sticking vents) within a few miles, I'll be getting around to changing actuation motors when things warm up a bit, no garage so I don't fancy freezing! But I suspect my headline condensation started as a result of the air con issue.
    My point is, that if there is already a hidden source of moisture behind a panel or under a carpet, then this will be suficient to steam up your windows when you leave the car, particularly if there's a bit of sun and then a cool afternoon/evening to get the vapour moving and then condensing.
    If you can find the source that's half the battle. Then you just have to sort out the cure! ...that's where I am ...I REALLY don't want to have to take out my head lining, but what's my alternative?
  25. wwfc
    wwfc New Member
    I think you'll find problems with windscreen condensation is due to the fact that when you switch off the car with cc on , the 3 flap motors do not fully close. Therefore on cold windy days/nights air can flow directly thru the demister vent. If you select air to the footwells before switching off this should fully close demister vent and prevent condensation!!!!
    A4sportMrT likes this.
