Concert II to RNS-E & Bluetooth conversion
s8craig Nov 19, 2006
  1. s8craig
    1,752
    55
    Here are some pics of a job I did this weekend, standard Concert II to RNS-E DVD navigation and Bluetooth.
    Before with Concert
    After with RNS-E & Bluetooth
  2. SteveTDCi
    SteveTDCi Active Member
    1,407
    Looks good, how easy is it to change from the single to double din ? is it cheap ?
  3. s8craig
    1,752
    55
    A3 is probably the hardest to do, as trimming the aircon is tricky and removing the cage is a pig. This install took 4 hours. The DIN conversion needs around £150 worth of parts. Then the costs of the RNS-E and bluetooth parts.
  4. oldlaw
    oldlaw Member
    144
    looking good. what happend to the duck! :shrug:
  5. s8craig
    1,752
    55
    No ducks were harmed during this upgrade...
    It was relocated by it's owner
  6. rich1068
    rich1068 Member
    674
    That looks superb!
    Go on then. From start to finish, everything included, how much? PM if you wish.
  7. Granny
    Granny Member
    66
    did a good job trimming the Air Con! I don't think i'd have the balls to have a go at it tbh... Looks a very professional job.
  8. killbill
    killbill Member
    37
    I have to say I am well impressed with this, looks the dogs cohonus. How easy would it be to retrofit the latest phone prep into the arm rest ?
  9. ren
    ren Member
    50
    i'm well impressed too ... as it's my car! car now feels complete. total dream.
    and it's the car's duck (donation from embarrassed son). permatan ducky made it to the back seat and although he made it through the retrofit safe and sound, he's sadly currently covered in glass dust and flakes after a bit of piston came flying through my windscreen last night.
    thanks craig. i'm looking forward to getting my car back tomorrow with new glass and playing around more with all these new toys.
    a highly recommended and all-round satisfying experience for any of you considering it.
  10. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    If you don't mind me asking, how did a piece of piston end up through your windscreen?
  11. Wolfsburger
    Wolfsburger Member
    140
    Just thinking the same myself!
  12. s8craig
    1,752
    55
    £1600 for the lot, Sat NAV, conversion and phone prep.
  13. s8craig
    1,752
    55
    Why do you need the prep in the armrest, 99% of users do not ever plug the phone into the prep cradle, so bluetooth only is enough at £400.
  14. ren
    ren Member
    50
    it blew out of the bottom of a citroen xsara on the m6 toll, bounced off the carriageway. i managed to miss the other bits of flying engine luckily. i'm going to only follow german cars for a while.
  15. killbill
    killbill Member
    37
    Thought you need the full prep for the bluetooth to work, obviously not, do you need the MFSW for the bluetooth install to work ?
    :p
  16. s8craig
    1,752
    55
    The bluetooth prep will work with nothing installed at all except concert/symphony/RNS-D and the phone prep, it basically acts as a send and receive device, names and numbers will pop up on the DIS when the phone book has transferred and you set you phone to auto answer.
    If you have a MFSW, then you can control the phone through the wheel and DIS and make and recieve calls as long as your phonebook transfers. Also you get voice control of the phone.
    If you have the RNS-E nav system, you don't really need the MFSW, as you can control the phone from the nav screen. But the MFSW helps as you get voice commands as well.
  17. killbill
    killbill Member
    37
    Thanks for the info. Mya well be in touch when the A3 arrives.;)
  18. Caesium
    4,879
    what bits are required for the bluetooth?
  19. alfiejts
    alfiejts Member
    352
    what bits are required for the citroen xsara?
  20. Vertigo1
    Vertigo1 Well-Known Member
    3,387
    547
    Out of interest, what voice commands does the BT kit support?
  21. benw123
    benw123 Moderator
    1,863
    LOL :laugh:
