Concert II Swap
gmx Dec 24, 2012
  1. gmx
    gmx Member
    148
    Finally got a Concert II from an A3 (8P0 suffix). Apart from fascia, is there anything else to swap to complete the mod?
    Is DIS good to go or needs a some pinning/wiring?
    I also have an XCarlink adapter which I assume will work since the stacker plug is the same?
    The car is a 11/99 build digital clock.
  2. Sulli79
    Sulli79 Active Member
    541
    37
    You will need a canbus adaptor from kufatec.de, or similar, think the kufatec one is about 80 euros
    http://www.kufatec.de/shop/media/images/popup/453_0.jpg
    dont know if any coding is required after?
  3. Sulli79
    541
    37
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,945
    736
    You may not need a can-bus simulator, most/all facelift B5's have infotainment can-bus on the instrument cluster however you will need run two wires can-high & can-low to the back of the cluster (from memory the infotainment pins are 5 for for can-high and for 6 can-low, but I would check that!) You may also need to change the coding, see if it would accept A4/A6 coding as you these cars don't have can-gateway.
  5. Sulli79
    541
    37
    Does the infotainment do the lighting and ignition though? I didn't think it did?
  6. B5NUT
    3,945
    736
    It will, however if you retrofit RNS-E the clock is always out so you would need something called a (google search "Bjarne CANGate")
  7. Sulli79
    541
    37
    Result, I imagine with the digital clock you will be can bus ready then,
  8. gmx
    gmx Member
    148
    Ok I'm guessing it's these:
    Grey 32 pin connector:
    [TABLE="width: 100%"]
    [TR]
    [TD]5 - CAN high speed display (high +)[/TD]
    [/TR]
    [TR]
    [TD]6 - CAN high speed display (low -)
    Anyone know if these terminate in the footwell somewhere or underneath the ECU area?
    ​Just looking for a clean area to splice from and run to the centre console area... and would like to avoid messing with the cluster connector area.
    [TR]
    [TD]Looking at this diagram, I'm not sure which pin it's suppose to go to? Are they unoccupied in the B5 and require a pinning tool?
    [/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [/TR]
    [/TABLE]
  9. B5NUT
    3,945
    736
    As I said in my post they will not be any infotainment wires running from the cluster, you will need to get pins from kufatec or harness repair wire from Audi.
  10. gmx
    gmx Member
    148
    Is there a link to the harness from Audi or a PN?
  11. gmx
    gmx Member
    148
    Ok, just to test fitted it since I need to modify the faceplate (rather than buy an A6 one etc) and sometimes the front speakers don't play.
