Concert double din radios retrofit
F2 Jul 5, 2013
  1. F2
    F2 New Member
    13
    I'm currently ripping out my single din radio, climate control and cage assembly in my 2006 A3 s-line, to replace it with a double din cage assembly ready to receive a rns-e later in the year... (Probably my Xmas present to myself!) so, in the meantime, I am looking to put a double din concert radio in the large gap! I have been looking on ebay for a used one to come up, but they all seem to say 2007 onwards? Is it not just as simple as a straight swap, single din for double din? Also is it easy to get a radio code for a second hand set? Is this something I can do with vcds?
  2. fangio
    fangio Well-Known Member
    1,497
    179
  3. JPK
    JPK Active Member
    303
    Rnse uses your existing antenna amplifiers. Double din concert uses a different type again, so you would have to swap out twice.
  4. JPK
    JPK Active Member
    303
    Does the double din concert need an aerial adaptor also?
  5. fangio
    1,497
    179
    Simpler to do RNS-e first. Put the price of a Concert to it!
    I have a 2005 and did the d/din and symphony conversion first, but I wish I'd gone straight for the RNS-e......
    No antenna problems.
  6. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I converted mine from single concert to a rnse in 3 hour, but I don't have the hazard button trim yet as I'm not paying the price the stealers want! Might get the facelift buttons just unsure how to mod buttons!
  7. F2
    F2 New Member
    13
    Ok, we'll may just put in an rns-e straight away, if it makes life a lot easier! Managed to get myself a cracking deal from a breakers yard... Double din cage, all the buttons and trim for £50 or £75 with the dual climate panel... Bit his arm of with that, then realised the dual climate didn't have the heated seats.... So ended up with most of it from there and got another climate on ebay, just being lazy as could have trimmed my old one down I suppose!
    Best to go for the newer rns-e with the glossy screen trim? I think they end in G part number? Also do I need the plug and play loom and antenna adapter for the rns-e?
  8. JPK
    JPK Active Member
    303
    Which wrecker had the climate? I need a nice and cheap one and don't need heated seats.
  9. fangio
    1,497
    179
    Not hard to shave the single din to fit, just a bit at a time.
  10. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Hi fella, I have a symphony 2 double din unit which has the 6 cd changer built in. I don't have the code for it, so you will need to find that out, but if you want the stereo, looking for around £30.
    It will be a straight plug and play as it uses the same iso connectors.
  11. tates1979
    tates1979 Member
    52
    I'll buy the single din concert unit off you if you're looking rid! (provided you have code!)
