Concert 1 with no amp on rear speakers
dermot Jun 11, 2005
  1. dermot
    dermot Member
    34
    Hi, this one is for Andy
    Asked this before but cannot find your reply
    Have a Concert and want to put it into 96 1.8T Sport.
    Car does not have amps on rear speakers
    Is there any way to get the Concert to power the rear speakers without the need for a separate amp
    Noticed line-out section on the Concert for a RCA type connector
    What is this for ?
    Thanks Dermot
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    All A4's have ampe rear speakers, the amp is bolted to the left rear magnet.
    So unless someone has replaced the rears the amp should still be there.
    If it isn't then your best bet is to buy a small amp on ebay (like an Alpine 3520 or 3522) nothing too big otherwise you'll have to run a new power cable and wire this up to the pre-installed pre-out lead in the boot. You can pick these amps up for less than £20.
    There is no way to wire up a Concert without using a rear amp as it only has one 2 ch amp built in for the fronts.
