Comp housing clearance
SamHendry
My ko4 turbo comp housing outlet is touching China fold... I shaved a bit off the manifold and clearance is about a fag paper... How close can these sit together.. I could open it up to 1mm I reckon... Anyone have any idea how close these can sit together?
Thank you sir.. Now I can crack on with this..china fold is being a slight pita... Lugs that sit above the top row of nuts were fouling on the head, had to shave 2-3mm off then of course it fouled on the comp housing of the turbo and now turbo support bracket is stopping me from marrying the turbo to the manifold...***.. Getting there tho..
God knows how people fit these manifold with engine/head in the car...fiddly enough when it's out the car!
Reactions: IPG
Interesting.
Didn't think the China folds were that much of a pain to fit with!
Is it all ported and polished?!?
got to luv china products! not!
Interesting.
they're not if you know what you are doing and have experince of them
only 1 nut is tricky and needs to be put on first sequence wise and that can be made easier by using M8 10mm AF go kart wheel nuts ;)
Interesting.
Yes It badger 5 ported..purchased from asn member and previously fitted to a s3 which made me think it would go straight on but that wasn't the case.. heads must different..
All heads are the same on the exhaust side aren't they??!
Looking back I think I only had to remove 1mm from the manifold and it wasn't all the lugs just a few.. As said previously was fitted on a 1.8t head prior but didn't fit mine without slight fettling. Suppose it's small amounts but can only assume there is a slight difference in the head otherwise would have bolted on fine first time or China fold has been bent out of shape...hmmm..its on now mated to a k418t :)
Reactions: IPG
heads do indeed vary on the top face machining on the exhaust outlet face.
720
711
505
14
942
