On a recent, 300mile round trip, I started getting some hesitation under heavy acceleration, which happened about 3-4 times in a space of about a week. As a result I started playing about with VCDS and doing some logging on the car as I was mainly interested in checking how well the MAF is working or if I had some serious boost leaks or engine controller errors.
I found no errors, but while doing this, I found that actual v's requested boost is consistently lower over the rev range, with the MAF readings showing air flow maxing out at 198g/s, which is a bit poor for a mapped AMK S3 (correct me if I'm wrong please).
So, for all you turbo wizards out there - What are possible causes of the missing boost?
My thoughts are that it's a boost leak or whichever valve that controls the boost level is stuck open, which prevents the turbo to deliver the requested boost. Could it be a limping turbo on it's way out? It's not smoking or showing any other signs of going.
I am running a stock DV and have a Forge 007P knocking about from the old car, so could try that. But before I start trying things out blindly I want to get people's opinion on other possible causes and if additional logging is in order to confirm the root cause. If the latter is true, I'd love to know the blocks I need to log as the latest version of VCDS does not have a lable file for my engine controller, which makes it a little tricky to decipher the meanings of some values
Here is a sample of the log I took earlier today:
RPM .Req ...Act. ..Mass Flow
.........Press Press
/min .mbar .mbar .g/s
1400 1820 1080 23.06
1520 1830 1110 26.19
1640 1840 1150 28.69
1760 1880 1200 32.61
1920 1980 1250 38.5
2080 2150 1320 48.28
2280 2320 1440 61
2480 2400 1620 78.06
2760 2440 1930 109.14
3080 2480 2400 130.08
3440 2520 2430 140.28
3800 2550 2350 148.72
4120 2550 2320 163.86
4480 2520 2330 169.47
4800 2450 2210 174.06
5120 2430 2130 178.69
5440 2410 2090 185.33
5720 2370 2040 190.53
6000 2330 2030 193
6240 2340 1990 194.25
6440 2330 1960 194.11
6640 2320 1920 198.06
6840 2300 2030 197.42
7000 2290 1950 126.08
6760 990 1760 5.22
Full log is here
Tell me if I'm going on a wild goose chase and the car is fine
Cheers for the help.
1920 1980 1250 38.5
2280 2320 1440 61
6000 2330 2030 193
6760 990 1760 5.22
Full log is here
