Command vs Actual boost ??
Essflee Feb 20, 2011
  1. Sandip
    2,456
    99
    Interesting, once mine is mapped i'll do some logs of the N75 connected at the chargepipe and another connected at the inlet
    Dave i know what you mean, i wonder if it makes thing more accurate or less accurate???
  2. Westy
    Westy Well-Known Member
    17,443
    1,104
    Very interesting. This is the first ive heard of taking the reading from the inlet.
  3. Prawn
    11,538
    3,489
    doesn't sound like a good idea to me. For more accurate boost control you want to N75 take off as close to the turbo as possible. You'll get different spool and boost characteristics on part throttle I'd have thought, but I wouldn't expect too much difference when you're flat out.
    What's the idea behind it? I can see the theory if the N75 worked like an MBC just cracking at a given pressure, you'd be negating the pressure drop within the system. But seeing as the N75 is simply controlled by what it sees at the map sensor and airflow, I don't see how it'll make any difference
  4. <tuffty/>
    21,364
    3,931
    Makes no sense to me... the ECU applies a duty cycle to the N75 based on the reading from the MAP sensor to meet the requested boost in the map... got shag all to do where you take the N75 feed from...
  5. gez
    gez S3 hunter
    109
    Of course it does! So why does it take a boost feed from the system atall then??? Its basicallu an electronic bleed valve. Gets to set boost then opens and bleeds the rest back to the tip insted of to atmosphere.
    If you have n75 connected to charge pipe, why have your boost gauge on the manifold, there both getting different readings.
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    You need pressurised air to open the actuator.... that's what the N75 actually regulates. There is no pressure sensor in the N75 valve at all - it simply opens and closes, and allows pressurised air into either the actuator pipe to open the actuator, or vents it back into the TIP as it's not needed.
    The MAP sensor is what sees the pressure, and the ECU opens the valve to accomodate. The physical pressure that the N75 valve sees is neither here nor there!
    The actuator pressure is about 6 PSI. It doesn't matter whether you get the boost source from the inlet manifold, or the charge pipe, it is going to be enough to do the job of opening the actuator.
    I'd suggest doing some reading on the subject before dictating to people what things do and don't do, when you obviously don't know yourself.
  7. Welly
    10,696
    129
    Sorry for any who are now confused by all this - and the complete and utter waffle that has been posted.
  8. Westy
    17,443
    1,104
    Not confused, but interested.
  9. Welly
    10,696
    129
    If anyone wants to give it a try, then go for it.
    The only difference it will make is a bad one. The less pressure the N75 gives the actuator (i.e like taking the feed from a source with less pressure - going from charge pipe (higher pressure) to inlet manifold (less pressure)) at the point of there being a need to open the wastegate will result in more of a boost spike.
    If you are changing the setup so that the N75 feeds the actuator 21 PSI at the manifold, instead of (for example) 28 PSI at the charge pipe, what is going to be the result?
    It doesn't take much to figure out that the result is more sluggish actuator (and thus boost) control, due to the reduction in pressure to force the actuator open. The more pressure available, the quicker the actuator will open the wastegate.
    And that is pretty much it in a nutshell. End of.
  10. Westy
    17,443
    1,104
    I was wondering why In 2 and a half years i'd not heard one person mention anything about plumbing in the N75 differently.
  11. <tuffty/>
    21,364
    3,931
    Probably because VAG spent eleventy billion quid in R&D putting it where it currently is... :)
  12. superkarl
    superkarl MAN OF STEEL
    9,495
    2,436
    I'm going plug my n75 into my anus, thus giving a better reading of what's going on in the engine when I fart. Similar theory
  13. Welly
    10,696
    129
    :applaus:
    The more you fart, the less boost you'll have....
  14. Westy
    17,443
    1,104
    haha, pics!!!!
  15. Welly
    10,696
    129
    Ummmm, I'm unsubscribing from this thread..... :undwech:
  16. Sandip
    2,456
    99
    We'll have to do some logs to compare:fart:
  17. superkarl
    9,495
    2,436
    Westle I had up most respect for you until now, wishing to see a hose going from my anus to my n75 valve. That's perverted car porn, like necrofilia is to conventional porn! Dirrrrty dirrrty bastar......
  18. superkarl
    9,495
    2,436
    Sandip if we were to do logs it would block the pipe!
  19. Westy
    17,443
    1,104
    haha, this thread has taken a big turn for the worse me thinks!
  20. superkarl
    9,495
    2,436
    Sooooooo, leggy, your car is ok in the end. Excellent! Happy motoring.
  21. Essflee
    Essflee Well-Known Member
    2,146
    67
    Lol :)
  22. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Let him get on with it, i say......
  23. Biggied
    Biggied They called him mellow yellow.
    198
    Well done Welly, a good explination there, if anyone still has any doubts over this then I suggest reading up on the subject a bit more & don't post anymore arguments towards the statment as you really don't understand whats being said.
    Ewan.
  24. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    haha you guys slowing go off the topic, Karl and Westle..... funny guys lol
    I was talking to a guy I know about this few weeks back about taking the feed for the N75 from the manifold, was interesting when you think about it.
    Nice info though Welly, although it would still be interesting if sandip still did some logging on this.
  25. Essflee
    2,146
    67
    Right...
    Was confused as to why liquid gauge appeared to be showing different results to vcds, so tonight I've tried some more runs in 3rd 4th using the liquid S3 to see what request vs actual I was getting.
    Strangely now everything seems to be fine, the liquid gauge was showing the same results as yesterday with the vcds, a good thing obviously :)
    I've read that if you put a new N75 on a car it can take a while for it to adjust to the car, how true this is I don't know but the day after having the new N75 fitted I tried the liquid gauge and it was showing to much actual boost...
    In short really, whatever the reason I'd like to withdraw my comment on taking the liquid gauge results with a pinch of salt because it's now reading spot on.
  26. Broken Byzan
    13,237
    465
    Because there is no gain to be had. The N75 just regulates the pressure that is sent to the wastegate to open it. It has no idea what the pressure is, it doesn't care either,lol
  27. badger5
    9,507
    2,003
    Its *ALWAYS* been reading it as it is...... Its feeding off the same ecu data
    the inconsistency is your logging and comparisons, different gears, different throttle, different N75, different days etc etc etc etc etc ..
    What does it read on the 5th/6th gear 2krpm full throttle application? >2550mb
  28. Essflee
    2,146
    67
    Bill, just tried 5th and 6th from 2000rpm and was seeing a gradual increase in boost as the revs built up peaking at aprox 2440mb so all seems well, no harsh spike or readings exceeding the map sensor...
  29. badger5
    9,507
    2,003
    Excellent
    Excellent news
