Coming/leaving home not working
master83 Dec 6, 2012
  1. master83
    master83 New Member
    23
    Hi!
    I have just bought a 2005 A3 2.0 TDI DSG and I´m wondering how the coming/leaving home function works. I have a button below the light switch with the symbol of a clock and a light, but nothing happens when I push it. -I´m guessing it should switch a red light on/off right?
    Any tips for troubleshooting?
    Thanks!
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,432
    9,431
    Hi, welcome to audi-sport.net. Have a read through the faqs threads at the top of this section, lots of useful info in there. Enjoy the forum. :) x
  3. hades-
    9,481
    646
    you turn it not push it
    turn it on get out the car lock it
    only when its dark tho.
  4. Boon
    Boon Active Member
    441
    59
    First I'd remove the light switch - turn it clockwise from the off position about halfway between the sidelight and off position while pushing the whole switch in, then the whole switch unit will come out towards you - it requires a little bit of a knack but you'll soon get it!
    Then you will be able to see if there is a connector to the rear of the little switch for coming/leaving home - if not then its a retro fit switch - if there is then it could be a wiring problem or may need activating for whatever reason with VCDS
    It will be possible to get it working either way but hard to diagnose
    Do you have a light sensor in the windscreen behind the rear view mirror?
  5. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,275
    287
    That's not the dial brightness adjuster is it?! ;)
    I didn't think that there were any buttons for the coming home lights and they were activated through DIS? And only if you had the auto headlights?
  6. master83
    master83 New Member
    23
    This is the switch I have (but I have two fog light options)
    and yes, I have light/rain sensor.
  7. Daggerit
    1,275
    287
    Gotcha! Never seen that before, looks like you're right! :) No idea then. :/
  8. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    Have you tried it in the dark? The coming home/leaving home lights only work in the dark.
  9. master83
    master83 New Member
    23
    Does it have to be dark to activate it via the button?
    Anywho: It's always dark here now up north :/
  10. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    344
    58
    Does the red LED light up when you press the Button? Do you leave your switch in auto? and do your autolights work?
  11. master83
    master83 New Member
    23
    No the button does not light up.
    I have the button on Auto.
    when in auto, the xenons are on - not sure how to test if the autolights are working.
    No error codes in vagcom either.
  12. jb0o
    2,663
    116
    Strange.. The red light should come on or go off when pressing the button, regardless of being dark outside.
    Give the autolights a test by putting a peice of paper on the windscreen over the sensor, just underneath the rearview mirror.
  13. master83
    master83 New Member
    23
    I will try with a flashlight later tonight. also check in VCDS if the feature has been turned off for some reason.
  14. A19quattro
    A19quattro Active Member
    605
    91
    Maybe someone's had the switch out and not reconnected the wires it at the back?
  15. master83
    master83 New Member
    23
    It was disabled in vagcom.
