Coming/leaving home lights and LED number plate bulbs?
C20JCK Aug 11, 2011
  1. C20JCK
    C20JCK Member
    30
    hey
    im new here :) ive finaly got my A3!!!!! its a Ibis white SB BE MY11 orderd in may!!
    just a few questions guys if youd be kind enough to enlighten me lol
    i dont think they come with coming/leaving home lights, i was wondering if it was able to be activted or do i need to retrofit them?
    also the number plate bulbs, i was told if i fit normal LED's it will flag a light on the dash? which bulbs wont lol?
    cheers in advance
    Craig
  2. Paullie
    Paullie Banana Menace! VCDS Map User
    2,076
    288
    Hi Craig, AFAIK Coming Home lights can be activated using VCDS cable, but Leaving Home can't be done on newer A3's :(. There are currently no number plate LED bulbs on the market that won't trigger the bulb out message, believe me, I've tried many types, lol. However a member overseas (Pretarion) has done a retrofit of LED plate lights, but it involved attaching resistor packs to the tailgate and this means taking the inner trim off and I believe the packs had to be screwed into the body. I have the parts to fit to my car, but haven't got round to attempting it yet. Have a look at this thread. :) Paula x
    http://www.google.co.uk/url?q=http:...cQFjAI&usg=AFQjCNE7N-TIVQyethU2fKt3OYrEio_bVA
    Welcome to ASN, BTW! :wub: x
  3. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    That sucks about leaving home lights! Miss that feature off my Leon Cupra :(
    Need to get coming home lights done though, and still want to attempt the LED plate lights :)
  4. C20JCK
    C20JCK Member
    30
    Thanks paullie
    So is coming home lights when I unlock my car the DRLs come on?
  5. Paullie
    2,076
    288
    No Bud, those are the leaving home lights. The coming home ones are when you lock the car, get out and the DRL's are on. As you say, it's a shame we can't have them:) x
  6. C20JCK
    C20JCK Member
    30
    I found this on here
    "I bought a repair cable from my local Audi today, the part number is 000979009E and cost �2.13, fitted and activated it via Vag-Com and its a brilliant very cheap mod to do."
    There's a guide somewhere as well it envolves adding a wire done near the fuse box in the dash? Can anyone confirm if this works on the MY11 models?
  7. Paullie
    2,076
    288
    I know we don't need to add the wire in order to activate the coming home lights, it just needs coding via VCDS/Vag-Com (Central Electrics , then you activate it via the DIS in your car and it'll work. Don't know about the leaving home ones though, Dude. :) x
  8. paddy
    paddy Audi=No fault code, no idea
    5,152
    132
    Mine was activated from the factory, just had to set it up on the DIS. I thought it was a BE std thing ?
  9. C20JCK
    C20JCK Member
    30
    Nope nothing in DIS apart from turning the convenience turn signals on and off
  10. Paullie
    2,076
    288
    There you go, Craig, according to Paddy, as you have the BE you might not even require VCDS to activate Coming Home lights! You may just need to go into your DIS menu and tick it in the 'lights' options. Didn't have this as standard on my MY10 S3, but activated it using my VCDS cable and then ticked it on the DIS. :wub: x
    EDIT Sorry, you must have posted while I was typing my last reply. :(
  11. paddy
    5,152
    132
    Maybe its just a S3 BE thing ?
    OH..hang on, you would need auto lights otherwise it would not know it was dark when you were leaving/coming home.
  12. C20JCK
    C20JCK Member
    30
    yeah i dont have auto lights thats maybe why?
  13. paddy
    5,152
    132
    Sure to be mate , sorry.
  14. C20JCK
    C20JCK Member
    30
    cheers paddy
  15. Paullie
    2,076
    288
    Craig, I don't have Auto Lights either, but I was able to activate Coming Home lights via VCDS and the DIS menu. It can be done, but I don't know about Leaving Home ones, ..this may need an extra wire added to a pin and activation. The thing is because I don't have a light sensor (to tell the car it's light or dark), my Coming Home DRL's stay on for 30 seconds even in the daylight as well as in the dark, which is no biggy for me. Just means I get to admire them when I get out the car, like the saddo I am, lol. If you have Auto lights, you can swap the coding over from Adaptation (like mine is set at) to Light Sensor, so they only come on in the hours of darkness. Hope his helps :wub: x
  16. C20JCK
    C20JCK Member
    30
    well yeah i would rather they come on in daylight aswell, im sad also :) haha might go a wonder into glasgow audi and see whats what tomorrow :)
  17. slade777
    slade777 Member
    763
    I will be activating this later :). I also read about putting in the repair wire but not a fan of messing about with that type of stuff!
  18. paddy
    5,152
    132
    Well if you dont mind them coming on in daytime i dont see a problem, good luck, let us know how you get on.
  19. Paullie
    2,076
    288
    Cool guys, it's Central Electrics (09) Byte 12, Bit 2 (0 = Auto Lights, 1 = Manual Lights). :wub: x
  20. slade777
    slade777 Member
    763
    Guys Im most probably being stupid:ermm: here but i have programed it and it now appears of DIS and gives options of changing the timing in 5 second blocks. What setting do i leave the light switch in? DRL, Sidelights or main beam?? Ive tried all but nothing happens? :shrug:
  21. Rhyso
    Rhyso Well-Known Member
    1,442
    286
    You tried in the off position? I've got a 57 plate and coded mine (don't have autolights) I've got coming and leaving home lights. If I remember correctly it took a couple of ignition cycles for it to start working
  22. slade777
    slade777 Member
    763
    Ive just tried it set to the off position and no luck. Like you say ill leave it and see if it works after a few ignition cycles. How did you do the leaving home lights? Repair wire or just coding?
  23. Rhyso
    1,442
    286
    Just coding on mine; I'll try and remember to grab a screen dump in the morning for you :)
  24. slade777
    slade777 Member
    763
    Cheers mate much appreciated :)
  25. paddy
    5,152
    132
    On mine setting the seconds to off has no effect unless you go to leaving home lights and set them to on first.
  26. slade777
    slade777 Member
    763
    Recoded it as Paula said and changed 0 to 1 in byte 12 but this then wiped the option on DIS. A few bytes further along I ticked coming home and leaving home lights this has put both on my DIS but still no joy with the lights actually coming on when unlocking or locking.
    Paula how do you leave the light switch set to DRL??? Did you only code byte 12 or another byte a few further along??
  27. paddy
    5,152
    132
    slade, did you do as my post above. Comming home will not work unless leaving home is activated via the DIS on the Factory install
    I do have to leave the lights switched to Auto/DRL though..Nige did a thread on this some time ago.
  28. Paullie
    2,076
    288
    Dude, will have a look at exactly what I have coded over the weekend and get back to you. I thought it was just Byte 12, but will find out for sure. :wub: x
  29. paddy
    5,152
    132
  30. slade777
    slade777 Member
    763
    Cheers guys all the helps much appreciated I'm going to have another look tomorrow and fingers crossed will sort it
  31. pat_986
    pat_986 Member
    67
    When you say there arnt any LED rear numberplate light that wont throw up a bulb out error, do you just mean on the newer A3's?
    I have fitted them to my 55plate with no problems?
  32. slade777
    slade777 Member
    763
    I think it's just MY10 onwards. I've tried loads for my 2010 car and none have worked but think 2009 and before work fine
  33. pat_986
    pat_986 Member
    67
    Oh, right. What does MY refer too, I.E. MY10?
  34. paddy
    5,152
    132
    Manufactured year
  35. pat_986
    pat_986 Member
    67
    Cool, thanks
  36. BlackEdition
    BlackEdition New Member
    19
    Did you get the coming home and leaving home lights both working? I get my new A3 BE Sportback without auto-lights at the end of september and would like to activate them both if it is possible?
  37. slade777
    slade777 Member
    763
    Not yet I've played around with all the options on VCDS and have both coming home and leaving home as options on DIS but they still don't actually come on :(
  38. BlackEdition
    19
    :( ... bummer! let me know if you get them working!
  39. khan_1212
    khan_1212 Member
    46
    Is it possible to choose which lights turn on when CH/LH is activated.. eg, sidelights and fog lights only or sidelights only etc.
    My car is a 2007 A3 tdi
  40. Rhyso
    1,442
    286
    I've not found an option on my 57 plate SB :( I've also looked at my mate's A3 on a 56 plate and couldn't see an option :uhm:
