Coming Home Lights
Ian_C Sep 13, 2008
  1. Ian_C
    Ian_C Dorsprung Turch Vechnique
    165
    Anyone ever used VAG COM so switch on this function - so that when you open the car you get front and rear lights on till you turn the ignition?
  2. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    Yes this can be done VERY easily if you have vagcom.
    Have a look at this thread for details
    http://www.audi-sport.net/vb/showthread.php?t=58299
    Basically in short you need a wiring coming from one of the electrical connections under the steering wheel which needs to be earthed to an earthing point on the car and then enabled on vagcom.
  3. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    ...unless you have bi-xenons, in which case it only takes a bit of coding!
  4. n00bie
    n00bie Member
    46
    I'll be getting my facelifted A3 in about a month!
    I was wondering if it was possible to turn the CH/LH function ON so only the LED's would stay ON?
  5. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
  6. RobinA3
    1,828
    47
    thats not true, i have bi-xenons and just doing the coding doesn't make it work, the earth wiring needs to be done too.
  7. Staz
    6,206
    67
    lol
  8. n00bie
    n00bie Member
    46
    LoL :)
    Any other way to turn it on?
  9. MarcQuinlivan
    2,539
    9
