Coming home lights
defsix Feb 16, 2011
  1. defsix
    defsix Member
    181
  2. will89
    will89 Member
    357
    I too want to know the answer to this...
  3. hades-
    9,481
    646
    you can retro them to the a4 b6 b7
    but not that way
    you need switch wireing etc etc
  4. defsix
    defsix Member
    181
    Are we all 100% on that ?
  5. hades-
    9,481
    646
  6. defsix
    defsix Member
    181
    Feeling a little sad now..
  7. mlody
    mlody Member
    184
    Its a big job to do, need a new mirror, light switch and a good bit of wiring. Im also 95% that you need a new windscreen that will support the light sensor
  8. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    Have a pdf guide off another forum for the A4/B6 retrofit - PM me your email and I will send it to you.
    New Light Switch + additional Coming home on.off switch, New Rear View Mirror, maybe new Power Control Unit, change quite a bit of wiring - VAG-COM but no new windscreen!
  9. mlody
    mlody Member
    184
    Are you sure about that? I wasnt sure myself, thanks though, might approach that soon since the new light switch with the auto function is on its way to me :p
    Oh and another thing, if you have the coming/leaving home function that you automatically gain the auto lights :)
  10. Woorlord
    951
    Ehh!? I have the guide so pretty damn sure!
    This question was asked recently and there is additional info on this thread.
    Auto Lights & Coming home lights - the guide I have shows how to retrofit these together.
  11. benjie
    benjie Well-Known Member
    1,223
    304
    I have *nearly* done this mod. Kept my eyes open on eBay etc for the right parts and accumulated them (at the right price) over the course of a year.
    It's a fairly hefty job, but a mate and I managed it in a day and I'm a bit 'special' when it comes to electrical stuff.
    You definitely don't need a new windscreen, the auto dimming mirror attaches to the standard windscreen mount (there is only one mount as far as I can tell - no auto wipers option on B6!) You MUST have a highline car (DIS with bulb out warnings etc) and your central electrics unit needs to be 8E0 907 279 F, letter E on the end will not work. I buggered up and got an interior mirror from a B5, which I'm told works, but I can't get it going. I want a B6 one with a button anyway - beware getting them from ebay. they's c£150 from a dealer and they regularly go for £200+ on ebay.de.
    Since I have a light sensor, I've also got auto dimming wing mirrors which connect directly to the interior dimming mirror. (£80 delivered from ebay)
    I used this guide. Reading the whole thread is advisable!
  12. defsix
    defsix Member
    181
    ooo.. lot of work... that mod in the a3 looks sooo simple...
  13. Woorlord
    951
    On inspection the A3 modification listed above simply tells the "09-Electronics Module" that "Coming Home lights is switched on" - this is what the additional repair wire connected to ground is doing. Of course you have to code this module to tell it it has the "Coming Home function". What it does not do is use this function in the dark - it's day and night functionality as there seems to be no light sensor - as stated in the instructions no light sensor rear view mirror required.
    This may work on an A4/B6 by adding a repair wire to ground to connection "T32b/24" on the "09-Electronics Module". What is not clear on the A4/B6 is if a light sensor is required for this full function to work. For reference the Photo Diode light sensor in the RVM is connected as follows: T32b/30 --|>|-- T32b/18. Note you will have to recode the "09-Electronic Module" for coming home lights and maybe the light sensor, etc. - info is on the Ross-Tech website.
    I would try this out and test but I only have an "8E0 907 279 B" module and would require a "8E0 907 279 F" module.
    If anybody has a spare compatible unit, send it to me and I will try it out.
    Otherwise perhaps someone else could try it?
  14. cfoster
    cfoster Member
    237
    I got this feature on mine!! Definitely handy if you've forgotten where you parked in Sainsburys!!
  15. quattrojames
    14,050
    575
    Surely you can't not spot a white S4!
    "Oh no hang on, that white S4 there isn't my one" lol!
  16. cfoster
    cfoster Member
    237
    lol!!!! Thing is its red now!!!!!!!!!!! Soon to be another colour, just not sure what yet!!
  17. defsix
    defsix Member
    181
    So if we were to do this we'd also need to dummy out(short) the diode so the module would think it would be dark all the time, I don't think that matters...
    |Does it matter which module is used?
  18. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    439
    Got them on my 1.8 T Quattro Sline - as an optional extra - the extra button is next to the headlight adjuster and the main headlight switch has auto listed on the switch.
  19. dejongj
    dejongj Active Member
    165
    40
    Same on my cabrio, like them.
  20. benjie
    1,223
    304
    It will work I think, but without the light sensor, it will behave as if it is dark all the time.
  21. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    anyone had any look with trying this mod?
  22. hades-
    9,481
    646
    the mod dont work on the b6/7
    only the a3
    you need full retrofit for it to work
