Coming Home Lights Coding Help
Isaa May 28, 2013
  1. Isaa
    Isaa Member
    123
    24
    Hi
    Im trying to retrofit coming and leaving home lights, I've done the physical installation which requires installing the audi repair wire but iv hit a snag with the coding.
    When i check bit 5 and 7 and select "Do It", I get a error message.
    If someone could tell me what I'm doing wrong it would be much appreciated.
  2. Ash187
    7,496
    744
    Your car doesn't use that coding, looks like you have a facelift car? You need to go through the different bytes and look for coming home active
  3. danb986
    danb986 In awe of VCDS Team Daytona
    523
    Does this mod still work on the facelifts? Mine's got xenons and LED DRL's, but not auto lights and I was under the impression from other threads that I can't do the repair wire trick like I did in my '07 A3.
  4. Isaa
    Isaa Member
    123
    24
    But mines not a facelift, its only a 2007 and I couldn't see the options that you mentioned.
  5. Isaa
    Isaa Member
    123
    24
    Could I also be having problems due to the fact I have a J Module fitted which is a Base and not a Highend.
  6. Isaa
    Isaa Member
    123
    24
    Bump!
  7. s3reptdi
    s3reptdi Member
    179
    I get this too so id like to know
  8. Isaa
    Isaa Member
    123
    24
    Anyone?
  9. Isaa
    Isaa Member
    123
    24
  10. Isaa
    Isaa Member
    123
    24
    Anyone
  11. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    345
    61
    Why are you trying to enable engine compartment light?
  12. Isaa
    Isaa Member
    123
    24
    On the guide I read it said to click bit 5 and 7 then press " Do it". Am I doing something wrong?
  13. Jay.Ing
    345
    61
    Looks like you've got an incompatible CE Module!
  14. Isaa
    Isaa Member
    123
    24
    :( Is there any way around this?
