Coming Home&Leaving Home+Needle Sweep on A3 BE 2009
Amirkhan2621 Aug 24, 2011
  1. Amirkhan2621
    Amirkhan2621 New Member
    Hi Guys,
    Ive got a 2009 BE Sportback A3.
    Just wondering how to activate the coming home and leaving home function and the needle sweep which ive seen on some audis...
    I dont have any software or hardware and just wondering can it be done through the DIS thats in the dash?
    Or can i go to audi and request this to be done...i presume it will only take a maximum of half hour to do?
    Amir Khan
  2. audigex
    audigex Active Member
    592
    45
    Needle sweep is only on the S3 as far as I'm aware.
  3. Amirkhan2621
    And the coming home and leaving home?
  4. NHN
    29,328
    1,708
    CH/LH to work properly requires wiring, light sensor & a button on headlight switch, there is however a hack but this means its on even during the day.
  5. Sock
    Sock Shark in a Goldfishes clothing
    576
    Should be a button below the day time running lights for the C/H lights ( a little rectangle one with a red light? )
  6. Avus Sportback
    Avus Sportback Member
    114
    Not so sure the above is true, just done the mod on my 09 BE and all works fine, one wire Block "E" pin 12 to earth - don't have the special button on headlight switch or light sensor and all works normally, only check Bit 7 in the Central Electrics.
  7. Ash187
    7,478
    735
    Amir, where abouts are you based mate?
    Could sort out the Coming home thing for you if your not too far
