Coming Home Leaving Home Lights
coxy8329 Nov 20, 2013
  1. coxy8329
    coxy8329 Member
    167
    19
    Not sure if this has been covered before; I don't recall reading about it, so may be of interest to someone.
    I enabled coming home and leaving home lights using VCDS. I never got around to installing the earth wire to the CE module.
    The results are:-
    Leaving home lights come on when the car is unlocked using the key fob.
    Coming home lights come on if the main beams are flashed after the ignition is switched off and before the key is removed, headlights come on when drivers door is opened.​
    My car is a 57 plate Sline SB with halogen lights.
  2. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    575
    Depends on what car youve got im sure... On xenons or what
    I activated mine easily through vcds, but that was after I needlessly ran the cable and connected it doh! Haha.. Maybe a bit more thread searching would have been a wise move for me..!
  3. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Iv attempted this, run the wire and got it coded up...... and no joy :(
    Is now on the back burner untill next year when its a bit warmer :cold:
    57 Plate A3 Halogen
  4. andyam
    andyam Active Member
    485
    You need to tap the wire on an earthing point once to activate it. Then just tape it up so it doesn't make contact again :)
  5. R90 STL
    R90 STL Well-Known Member
    615
    299
    can this be enabled for a car with xenons? I would be interested in doing that!
  6. Ash187
    7,520
    758
    yes they can be done on all cars up to 2010 models. the procedure changed in 2008 with the newer modules and do not require the wire as described in the first post.
  7. R90 STL
    615
    299
    i saw in previous threads there may be issues with 59 plates? Which is what my car is. Cheers
