Coming home and Leaving home lights - VCDS trouble
Pricy Jun 21, 2011
  1. Pricy
    Pricy Member Team V6 quattro Audi A4 Audi Avant Owner Group S-line owners group TDi
    99
    19
    I'm trying to do the CH and LH light mod like on this link to my 2007 A3 Link
    I've done all of the wiring and plugged in VCDS but if I go into the long coding helper and onto Byte 0 I only have Bit 3 and Bit 4 available as check boxes. Not the 5 and 7 as suggested in the guide.
    Is this function not available on my model or is VCDS being a bugger?
  2. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,662
    116
    Are you in module 09 - Cent Elec?
    What version of VCDS are you using?
    I know you can't add these to 09 onwards, but thats because there isn't even a Long Coding Helper available.
  3. Pricy
    99
    19
    Yep I'm in module 09.
    Using Version 10.6.2
  4. Pricy
    99
    19
    I should be able to just type the values in if somebody gives me the correct ones right?
  5. Pricy
    99
    19
    After a lot of digging it seems that I need an updated board as mine isn't a high end one. Does anyone know which board I require? Or can I update my one with the high end details?
  6. Pricy
    99
    19
    Finally found what I was looking for in this thread Link
    Anyway thought I would post this up in case anyone else ever needs it
    Looks like I need a new module to get these lights to work!
