Comfort turn Signals - Increase number of indicator flashes
Ads Oct 10, 2009
  1. Ads
    Ads License to drive
    8,230
    608
    Just wondering if there is a way to increase the number of indicator flashes you get when you tap the indicator stalk. I'd prefer an extra couple of flashes over the three you get.
    Had a look in vagcom but can only find the option of turning them on/off.
    Anyone help??
  2. NHN
    29,351
    1,720
    Not one that I know of mate as I wanted it myself, but when weather improves will have another look, thing is with the newer cars namely my10 there are more options being added to the DIS features to be controlled by the users, think its there cheap way of getting MMI style options in a **** small cluster if you get me, why they didnt just add it to the new rns-e my10 cars aswell, under the CAR menu's defies me, its pretty **** in DIS overall.
  3. scoTTy
    scoTTy Active Member
    1,962
    On the B8 A4 (with Stop Start) then this works. Not sure if it's tranferable but it's maybe worth a look :
    DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System):
    [17 - Instruments]
    [Adaptation - 10] -> Channel 77
    change 0 to 255
  4. NHN
    29,351
    1,720
    Gonna check the label file as it had to be an adaptation on newer cars, mines an 09 cluster so maybe I have already, if result then thanks in advance, if not then nothing ventured nothing gained huh
  5. NHN
    29,351
    1,720
    Label file isnt showing anything atm, need to check a MY10 car, cause also on these the new headlight switch is fitted with sprung loaded on/off instead of the push forward into position & stays until pulled back, which I wanted to fit but they have removed the steering angle sensor, so didnt work on mine as yet, watch this space.
  6. Sebastian
    Sebastian Member
    286
    Enabling the efficiency program without actually having the necessary hardware for it is IMHO totally worthless but I'd appreciate if somebody would enlighten me why one would want to do so. :)
    When it comes to changing the Number of Comfort Turn Signals, this wasn't possible prior to MY 2010, as of now with the new BCM the setting can be found in Adaptation of the named module.... so what you need to do is...
    VCDS > Select > 09 - Central Electronics > Adaptation - 10 > Channel 31
    FYI: Label Files for some of the stuff is encrypted these days, so you may not be able to actually check into those files offline.
  7. NHN
    29,351
    1,720
    Thanks for the channel info, gonna go check see if my newer 09 module has anything as its a 30byte now.
    Well I've upgraded some parts Sebastian, which is why I always like to look & test things to find out how they work & what modules they work from.
    I like new options on my car, expensive hobby but hey, better than sucking on a cancer stick, pissing it down the toilet or sucking it up your nose huh, lol.
    I have got the 30 byte highend & there is an option for coming home logic old/new, do you know what this does as yet & also the newer headlights stalk is sprung loaded, does this also depend on the 09 module or is this to do with the steering ecu as I have the newer steering ecu & stalk but cant see any coding for this to work, where as older pre MY10 all had the push forward into locked position for high beam.
    Also nobody is enabling options they dont have cause the label file should only show the relevant options for that particular module surely, so there wont be an option to enable if the files dont have this present for the said cars module version.
    Are they encrypted mate as I have been able to open them all fine.
  8. scoTTy
    1,962
    Firstly, apologies for putting it in this thread. I thought I was elsewhere!:blush:
    As for why, the DIS information can be useful if you're in the mind to save fuel ... even if you don't have Start Stop. i.e. it shows want ancillary devices are using the most fuel (A/C, rear window etc) plus theirs improved mpg pages and an enhanced recommended gear page.
    It's not compulsory so if you don't want to then don't...but some might. :shrug:
  9. NHN
    29,351
    1,720
    Ooooh this is interesting, now you got me intrigued, I do love technology
  10. MatriX68X
    MatriX68X New Member
    Hello everyone
    My name is Mauro and I write from Italy and I own an Audi A4 MY2010, after making some changes VAG I lost this "Comfort Turn Signals" inexplicably, I can indicate the control byte and bit to wake up?:banghead:
  11. MatriX68X
    C'è nessunooooooooooo!!!!!!!!!!!!!!!!!!!
  12. NHN
    29,351
    1,720
    Cosa?
  13. MatriX68X
    Hello
    Sorry I have a problem I realized that I lost the function of the three touched with flashes of the auction arrows.
    I no longer turn, does anyone know what to do?
    I write from Italy, I would be very grateful if you help me ..
  14. NHN
    29,351
    1,720
    Dove abiti in italia?
    My partner is italian & I will be moving there soon.
    Have you or a dealer been changing coding on the car with vagcom?
    Do you have vagcom as you will need to enable it in long coding.
    Module 09, Byte 02, Bit 1 (Comfort Turn Signals) tick the box, this is for a 30 byte module, yours maybe different box to tick.
  15. MatriX68X
    Thanks for your interest
    My name is Mauro my city is located in Livorno, Tuscany (central Italy) possess an MY2010 A4 Avant.
    At the Centr. 09 -> Byte 02 -> Bit 1 I (Daytime running lights by front side marker lights active) and I have not found in any other Bytes of the Centr. 09 (Comfort Turn Signals).
    Many descriptions have not Bite Bit ...
    I'm probably other functions in activating this option, but I can not figure out where ...:crying:
  16. NHN
    29,351
    1,720
    Ciao Mauro.
    Si I have been to tuscany, we were to goto Livorno to get a ship to Sardenia.
    Ah ok, the original person who started the thread has an 8P, so I natirally thought you had an 8P A3.
    Just look for the setting comfort turn signals in your speedometer digital menus or in vagcom.
  17. MatriX68X
    My name is Mauro and I write from Italy and I own an Audi A4 MY2010, after making some changes VAG I lost this "Comfort Turn Signals" inexplicably, I can indicate the control byte and bit to wake up.
  18. NHN
    29,351
    1,720
    have you tried to do what Sebastian has advised?
  19. MatriX68X
    Yes, but probably not on the A4 B8 8K, it does not work ... :no:
  20. NHN
    29,351
    1,720
    So you have played with your coding, now you have disabled a feature & cant remember what you changed, do you not have a log of your old coding?
  21. MatriX68X
    Well! after several attempts to reset all settings, not gains no positive result, I went in the ECU 46 -> [adaptation 10] and I did a simple thing, I saved the "channel 0" (without changing anything) and like magic the three arrows and flashing back to work ...
    Now I ask you, why?:huh:
