Cold start - blue smoke
Macdoon Jun 5, 2013
  1. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    1,997
    758
    Hi all
    After hours of thread reading, still confused
    On cold start and up to temp, car is a wee bit lumpy, but puts out blue smoke and smells slightly, this only happens until up to temp.
    No fault codes. Injectors changed (on recall) 20k ago. EGR valve cleaned <10k ago. Oil & filter <5k ago and again yesterday with balancer shaft/hex drive upgrade. Full service (incl fuel filter) & cambelt change <20k ago. New turbo at 45k ish.
    Any ideas
    Cheers gang
    Mac
  2. unitzero
    unitzero Bagged B7 170 TDI Avant Audi A4 Black Edition
    568
    198
    43
    I have a very similar issue and have also read thread upon thread with no definitive answer. in for any info
  3. NickB
    NickB New Member
    25
    Are you burning oil?
  4. matthew999
    matthew999 Member
    146
    Macdoon, i think someone here changed the actuator on the inlet manafold, i tihnk it adjusts some flaps inside and this solved their lumpy idol issues, it might be worth a pop as apart from getting your hands dirty it is a cheep part
    cheers
    matt
  5. Macdoon
    1,997
    758
    No more than the usual fella, why what you thinking Nick
  6. Macdoon
    1,997
    758
    Cheers Matt, might as well start there lol
  7. tr3m5
    tr3m5 Audi Newbie
    34
    Blue smoke is burning oil, if it's only from cold then somehow while the engine sits cold some oil is getting into the combustion system, could be a number of things but if it was someting serious like head gasket or turbo oil seals you'd see other symptoms including high oil consumption.
    However if the valve guides and/or valve stem oil seals are are worn then when the engine is cold oil can seep down from the head and collect either in the chamber or back of the valve, when you crank you get a puff of blue smoke as the oil burns off.
    I'd get a compression test done anyway and check there is no emulsion in the oil to be sure if you're worried. General rule is on a high mileage car if you're not using too much oil then don't worry about it.
    Changing the actuator won't stop the blue smoke mind.
  8. NickB
    NickB New Member
    25
    The same as tr3m5 or shagged piston rings
  9. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    767
    Nick, shagged pistons rings generally shows up under engine load rather than a cold start. Valve guide oil seals are a favourite. Miller Oils do an oil treatment that can sometime help with leaky seals.
  10. Macdoon
    1,997
    758
    Had a quick chat with a mate, he thinks there is a possibility that maybe an injector seal may be the issue. Anyway asthe injectors had been changed under recall and a 2 year warranty I phoned Audi and it's booked in tomorrow morning to check the seals :ermm:
  11. Avnt
    Avnt Active Member
    240
    25
    What was the outcome of the blue smoke& rough idle? Mine does it as well and it had injectors done last september
  12. ajax1976
    ajax1976 Well-Known Member
    1,275
    656
    Sure it's blue smoke?
    Possibly coolant temp sensor giving false readings and over fueling the car on start up causing the smoke and lumpy running?
    Cheap and easy one to try first, unplug wiring from it night before then try starting next day from cold just to prove it first before replacing. Car will just revert back to generic values and should run fine with it unplugged.
    Alan
  13. Steve220
    Steve220 Member
    234
    15
    Overfuelling is black smoke. I'd go for your inlets are gunked up or valve stem seals.
  14. ajax1976
    1,275
    656
    On start up engine is obviously cold so if its overfueling the engine will struggle to burn the excess fuel, white smoke is vaporised(unburnt) diesel, hence the smell.
    Only a suggestion as I had exact same issue myself, only when starting from cold and lumpy, goes away once warm.
