Cold side relocation kit?
Jampublic Jul 10, 2007
  1. Jampublic
    Jampublic Taking it easy..
    974
    12
    Has anyone fitted a cold side DV relocation kit! Anyone, Anyone? Was just on the Forge website and spotted it, any thoughts on them? Unless, waste of money and time etc..
    Thanks, did do a search but nothing seemed to come up. :(
  2. Jampublic
    974
    12
    Anyone, surely someone must of heard of this kit! So no one has one fitted one :( I guess and no doubt its waste of time! :crying:
  3. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    Yeah a lot of people are finding its a good mod, as basically, instead of sending excess boost pressure round the whole system, it pushes it straight back in on the cold side.
    People are saying it gives better throttle response.
    Not done it myself and don't intend to, I've spent enough money with Forge recently...
  4. simch
    simch Active Member
    2,028
    Does this mean the "boosted" air is cold as it hits the dv, or just that the hot side boosted air is dumped to the cold side?
  5. Ess_Three
    Ess_Three Active Member
    5,383
    I fitted it to my S3.
    Basically, you dump the air from after the ICs (before the TB) back to the air inlet, rather than dumping hot air from a K04 running at very high revs.
    It seemed to help my silly high boost K04 S3 make DVs last a bit longer before they started to stick...but can't really say I noticed a difference in throttle response.
  6. Ess_Three
    5,383
    It sends the already cooled air back to the inlet hose, rather than the hot air heated bt the turbo but not yet cooled by the ICs.
    So, you should get better pick up as the engine is only trying to take in ambient air heated by the turbo, as opposed to hot air from the turbo's discharge, then heated again by the turbo.
    I never noticed any difference though...
  7. Jampublic
    974
    12
    Thanks for you information gents. :)
  8. simch
    simch Active Member
    2,028
    I presume you run a standard style dv, ie forge /bailey etc, or do you need a special type of dv?
    Reason its of interest is that my bailey was sticking at 85 degrees, in stock location. I would think on the cold side that it would never get that hot, not with my massive fmic anyway!
  9. Jampublic
    974
    12
    If you check forge website, you run it with a Forge DV or a OEM DV no doubt. Its appears to plumb in the same, just relocates the DV to the front!
  10. Ess_Three
    5,383
    I ran a Forge (I forget which) piston DV...and it used to stick, so I changed to am AmD Viper which was better...and better again after re-locating to the cold side.
    But I was running 1.8+ bar of boost...so lots of heat!
  11. Prawn
    11,583
    3,551
    ive just ordered a forge cold side relocation kit for my A3, in preperation for fitting my KO3s, FMIC, milltek turbo back, and custom map.
    im fitting it this weekend, so if i notice any difference, ill let you guys know :)
