Cold rattle
Discussion in 'A3/S3 Forum (8L Chassis)' started by twist123, Sep 21, 2009.
  1. twist123
    twist123 Member
    Jun 7, 2009
    186
    Hi,
    Hoping someone could diagnose a rattle that only occurs at cold start. Once warm cant hear it anymore.
    Its like a low grind / rattle at startup, can be heard very faintly when changing gear. Only occurs at certain RPM. So has got me thinking it could be a heatshield.
    I stuck my head by the front of the car and it seems its coming from a point closer to the front than the cat.
    Please help. Thanks
  2. Advert Guest Advertisement
  3. wagon
    wagon cock locked and ready to rock
    May 25, 2009
    130
    i think it might be the thing that warms the cat up... mine does it.. and its almost like after 1 min, it stops. then again it could be something else.
  4. twist123
    twist123 Member
    Jun 7, 2009
    186
    You may be onto something there, I just took it out and now that the outside temperature is quite a bit warmer it made no sound whatsoever. So whatever it is its got something to do with expansion/contraction.
  5. twist123
    twist123 Member
    Jun 7, 2009
    186
    This is the exact noise I have, about 1/5th of the way through the vid, that low grinding sound! Please help!
