Cold air from vents
vwgtiking Jan 24, 2014
  1. vwgtiking
    vwgtiking Active Member
    1,030
    I have climate control and have noticed my air vents are blowing cold air even when the temp is at 90. The only time it's starts to get warm ish is when I am driving in high gears ie 2.5-3k rev range.
    Pls note I have a 1.8t
  2. vwgtiking
    1,030
    Water pump was replaced at 93k and car is on 105k.
  3. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    Sound like an air lock in matrix
  4. vwgtiking
    1,030
    Thanks mike. How can I clear an airlock?
  5. Mike.M
    2,510
    170
    Open bonnet and remove coolant cap......put inside temp to Max heat and fans to Max speed......then getting the car temp up and keep revs to about 2k for a few minutes.
    Monitor coolant as if there is an air lock the level will drop and should not go below the minimum.
  6. vwgtiking
    1,030
    Thanks again mate
  7. vwgtiking
    1,030
    I have done what you have said and I think it's worked. At idle heat is coming out of vents.
    I topped up the water as was quite low. I noticed however a little film on water it expansion tank. Is this normal? It's not dirty at all.
  8. vwgtiking
    1,030
    Dipstick and oil cap no obvious sign of head gasket.
  9. Mike.M
    2,510
    170
    Good to hear.
    No film should be in the coolant tank? Is is oily?
  10. vwgtiking
    1,030
    It's like a few speckles like the film on a cup of tea
  11. vwgtiking
    1,030
    Come to think of it I believe I used my oil funnel to top up my coolant last time.
  12. Mike_B
    Mike_B Active Member
    533
    47
    :banghead:
    quattrojames likes this.
  13. vwgtiking
    1,030
    Lol
  14. Mike.M
    2,510
    170
    That would explain it LOL
    vwgtiking likes this.
  15. vwgtiking
    1,030
    I have just changed my temp sensor and lost a lot of coolant. I topped back up and bled system via the valve under the engine cover until water came. There was a lot of air. Anyway the above method doesn't seem to be working and coolant sploshes out of the top.
