Cold air feed for Badger5 with Cone Filter
B1GW1L Sep 25, 2012
  1. B1GW1L
    B1GW1L Member
    96
    Guys
    Is the standard air feed sutible for the Badger5 TIP and Cone Filter or would i benifit from removing it and installing a cold air feed.
    If it would what size tubing would i need and how much?
    Also if a cold air feed with ducting is suggested where should i position the intake of the hose, do i remove a fog light or can it sit some where else?
    Your input as always is much appreciated.
  2. <tuffty/>
    21,147
    3,833
    Std feed draws cooler air from under then wing to a sealed airbox... with a cone filter air will be drawn in from the path of least resistance so the surrounding air under the bonnet but obviously shielded by the heat shield (assuming you have the full kit)... I use a length of 4" ducting to feed air from the from of the car...
    ...and still use this now with my cone filter...
  3. B1GW1L
    B1GW1L Member
    96
    Yeah got the full kit coming so how long does the ducting need to be ? will a meter length do?
  4. <tuffty/>
    21,147
    3,833
    A metre should be fine... 3" will be easier to route... I used 4" as this was the only way air would be going into the airbox from when I used to run a panel filter..
  5. marlow77
    marlow77 Member
    75
    Tufty, if you enclose your cone filter in the box anyway how is it any different to a panel filter? cheers
  6. <tuffty/>
    21,147
    3,833
    Its not totally enclosed... surface area is key to flow... the JR/Jetex filter has larger surface area and flows more than the panel filter
  7. marlow77
    marlow77 Member
    75
    Sweet ;)
