Coilovers
Smithe95 May 1, 2014
  1. Smithe95
    Smithe95 Member
    84
    When lowering my audi a3 8p 57 plate using Coilovers , ( I know how to put them on and lower it) just wondering if there's anything extra I will have to, eg ... Under the car because it's lower ?
  2. smurfworth
    smurfworth Well-Known Member Audi S3
    1,939
    543
    Probably remove the undertray, either that or it'll be ripped off at some point.
  3. Smithe95
    Smithe95 Member
    84
    Fair enough , anything else ?
  4. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    depends if your front arbs bolts are stuck like mine were and just saw them off nd replace with new ones lol.
  5. smurfworth
    1,939
    543
    Not really, not a lot scrapes on these cars. Depends on how low you plan on going though.
    You'll probs need to remove the screw in the rear arches as ur wheels might rub on them.
  6. Smithe95
    Smithe95 Member
    84
    Cheers for all the suggestions
  7. GGG_666
    GGG_666 Black it out!
    207
    62
    Alignment!
    leeds2592 likes this.
  8. Keram
    Keram Active Member
    239
    39
    Going to put coilovers on mine also, so I've read quite a lot about that. There is a bit of chance you'll need to get some wheel spacers if you run stock rims, but that depends on the coils, so just have in mind.
  9. Smithe95
    Smithe95 Member
    84
    Cheers , just heard something about something to do with the drive shaft when lowered??
  10. Keram
    Keram Active Member
    239
    39
    If you go really low, probably you'll need shorter sway bar links, cause they could touch axles.
  11. Smithe95
    Smithe95 Member
    84
    Okay, fair enough :)
  12. Greenwood
    Greenwood Its a Deeerv thing
    49
    Mines lowered 90mm on back and front and it more or less catches on every speed bump so I'd be mindful if your going this low mate ! 🙈
    Smithe95 likes this.
  13. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Mines lowered on AP's as low as they can go and, apart from scrapping on the odd bump, I've not had to do anything else other than alignment which is a must!
  14. smurfworth
    1,939
    543
    What he said ^^ hah
