  1. Audibritz
    Audibritz Active Member
    203
    33
    Alright guys
    What coilovers are you going for? I've got a budget of about £400.
    links to them would be great
    Cheers Sam
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,461
    3,026
    Contact Damian at DPMPerformance. He's one of our forum sponsors, and will help you choose the best products for your budget.
    Macdoon likes this.
  3. ESD1711
    ESD1711 Active Member
    691
    219
    43
    I unashamaadely went for the budget option and got Damian to hook me up with a set of FK AK Street's.
    I'm well aware they arent the best kit out there, and fully expect them to have a relatively short shelf life....... but for that kinda money (£200ish) - i'll have no cause for complaint.
  4. DPM
    DPM Site Sponsor Site Sponsor
    5,055
    219
    Thanks!
    If I can be any help just give me a shout.
    Damian @ DPM Performance
  5. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    13
    I bought a set of FK Highports from DPM and the dampers are knocking really badly. I'm currently in the process of returning under warranty as i've only had them 4 months!
    So, be ware when buying budget coilovers!
  6. Audibritz
    203
    33
    Cheers guys I have the 2.0 tdi 170 sline FWD. Does the Quattro have the same suspension?
    Sam
  7. Steve220
    Steve220 Member
    234
    15
    Pretty much. I'd go for BC coilovers, great quality, UK made and great customer sevice. The ride on them is close to stock on an s-line.
  8. SL11CKK
    SL11CKK Active Member
    703
    37
    Does that mean its bad as the SLine springs make me think that my car is going to break its windscreen at times when going over bad roads.
  9. Steve220
    Steve220 Member
    234
    15
    Well if you've just got springs then I'm not surprised. I live in an area where the roads put the surface of the moon to shame and my suspension soaks it up fine.
  10. jdp1962
    8,461
    3,026
    I don't use coilovers; I have an SE running on Eibach 30 lowering springs and, for the moment, the original shocks. The ride is pretty good, arguably better that on the original springs. The problem with the crashy ride on S-Lines is very much down to the springs, in my opinion. So many people have reported an improved ride just from changing the springs to Eibach or similar. Personally, if I had a £200 budget, I'd spend it on good quality springs, and not low-cost coilovers.
  11. Audibritz
    203
    33
    My budgets £400, Does anyone know if the Quattro suspension is the same as the Fwd sline?
  12. jdp1962
    8,461
    3,026
    Ask Damian. I'm sure he'll know.
  13. ESD1711
    691
    219
    43
    I guess that comes down to what you actually want from the car though.
    Personally, spending £200 on springs which wont noticeable change the look of the car seems like wasted money for me.
    I've done the 'performance' suspension thing before on cars which I wanted to achieve the best possible performance from and wanted to take on track, but with the Audi - all i'm really looking for is the visual side of things. Its never gonna be a car I throw at corners or even contemplate taking near a track.
    Different folk want different things though, so its purely personal choice :)
    jdp1962 likes this.
  14. ESD1711
    691
    219
    43
    Pretty sure I remember seeing a few kits listed as "excluding Quattro models" - but as jdp says, fire Damian a message, he's the man who will know.
  15. Steve220
    Steve220 Member
    234
    15
    The rears will have a higher rate due to the weight of the rear diff and drive shafts, so yeh, slightly different springs but the layout is the same.
  16. olethalb
    olethalb Active Member
    357
    77
    i'd plump the extra for AP's mine have been very comfy (pretty low) comfier than the DTM stock suspension for sure, also handle far better than stock.
  17. Biddyy
    Biddyy Member
    40
    I'm after a setup too, aren't coilovers for those who want to go lower than a std lowering kit - i.e. more than an inch.
    The ride quality is in the shocks as the springs just hold the weight no?
    I thought a Bilstein b12 kit would lower an inch and give a quality ride and handling?
    What you think?
    I could be wholly wrong tho! :D
    Biddyy..
  18. Audibritz
    203
    33
    I might be buying some tein super street coilovers tomorrow but says there for the quattro. So need to know if they will go straight in or no.
    Im sure somebody knows out there....
  19. jdp1962
    8,461
    3,026
    At the risk of repeating myself, have you asked Damian at DPM Performance?
  20. ajax1976
    ajax1976 Well-Known Member
    1,279
    657
    Have you Googled it etc?
    I'm pretty sure they will although the rear springs will be stiffer than the ones for a fwd car.
  21. DPM
    5,055
    219
    The B12 kit is available in either a 30mm drop or a 50mm/40mm drop.
    Biddyy likes this.
  22. DPM
    5,055
    219
    Which kit were you looking at?
  23. Audibritz
    203
    33
  24. Steve220
    Steve220 Member
    234
    15
    and as soon as they touch the uk roads, they'll rust to pieces.
  25. DPM
    5,055
    219
    That's not a brand we do so you'll need to check fitment with TEIN themselves.
  26. Biddyy
    Biddyy Member
    40
    pm me a price for the 50/40 setup, cheers!
  27. DPM
    5,055
    219
    What engine do you have and is it an avant or saloon? FWD yes?
  28. Biddyy
    Biddyy Member
    40
    A4 DTM (2.0t fsi quattro saloon) 2006 b7.
  29. DPM
    5,055
    219
  30. Furkz
    Furkz Active Member
    303
    If I was you I would definitely save up for some decent coilovers like H&R or KW. I've run KW for 5 years in max drop without helper springs and never missed a beat. The car was literally an inch off the floor. So I can say yes they are pretty much great. The ride quality was also slightly worse than my s line.
  31. Darren198712
    Darren198712 Member
    194
    14
    BC Coilovers are very good quality. I had them when I had my Nissan. coat the coilover with copper grease and you should be fine. also they are not UK made. They are imported from Taiwan.
