Coilovers ... whats ones go the lowest?
tomb Dec 12, 2012
  1. tomb
    tomb New Member
    15
    As title says ..
    Any pictures to back up whats been said will be an added bonus.
    I have an avant but on any platform will do.
    Thom.
  2. Johnboymason
    Johnboymason Member
    73
    im after putting some coil overs on my a4
  3. SL11CKK
    SL11CKK Active Member
    704
    37
    How low do you want. Lowest you're going to go is not enough clearance for speed bumps.
    Check out AP's range. I heard FK's are good for stance
  4. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    If you want to go as low as possible try air suspension.
    You can usually get coilovers a little lower by removing the helper springs.
    Im going to be getting coilovers myself soon will be going for either Weitec or KW (Wietecs are made by KW so great quality)
    I have heard that the shock absorbers in FK's are a common failure.
  5. DPM
    DPM Site Sponsor Site Sponsor
    5,042
    212
    One of the FK kits will be the lowest option.
    Let me know if you need any info or prices.
    Damian @ DPM Performance
  6. tomb
    tomb New Member
    15
    Air ride is out of the question as the cheapest kit i can make up will be around the £1700 mark.
    Im looking to spend about £500 give or take a bit.
    Just looking for maximum lows with relative comfort.
    Damien do the FK coilovers come with any warranty on them?
    Thanks Tom
  7. RyanJonS4
    RyanJonS4 Drive It Like You Stole It
    557
    126
    43
    I've got AP-X? coils (adjustable rebound) and they dont go very low on the rear! Ive got them fullf wound down but would like another 20mm or so!
    Ryan
  8. DPM
    5,042
    212
    They do yes, all the FK range has 12 months warranty.
  9. N8
    17,163
    718
    Yes FKs from Damian ;)
  10. Malfuss
    Malfuss Member
    154
    I've got FK's on my Avant and they sit pretty low, low enough that I have to raise them this weekend. The arch is currently sat about 35mm above the actual rim of my tucked 18's. For cheap coilies I'm pretty happy with how they ride as well.
  11. tomb
    tomb New Member
    15
    Nice has anyone managed staticly tuck and wheel yet, not just tyre?
    How low to the weitecs run?
    N8; What Fks did you go for how to they sit?
    Tom
  12. TimG
    TimG Active Member
    942
    45
    Any FK's will go low as you can remove the helper spring. Not many other brands run a helper to remove!
