Coilovers for 8p2 A3 2.0TDI 170pd.
8385HJ Jan 11, 2012
  1. 8385HJ
    8385HJ Member
    101
    I have looked into getting coilovers for my car 2007 Sline Sportback S-tronic. I have found a set of FK Street Coilovers OR JOM coilovers.
    Basically what i wanted to ask
    how different are the suspensions for the S-tronic and non S-tronic? if at all. As well as S-line and non S-line.
    Do i need shortened drop links?
    Would appreciate any help.
  2. DPM
    DPM Site Sponsor Site Sponsor
    5,033
    208
    Morning,
    Both the FK AK Street and JOM kits are very similar in terms of ride and build quality and you should be fine with the standard drop links on both.
    S-Line suspension will be lower then non S-Line suspension.
    Damian @ DPM Performance
  3. TimG
    TimG Active Member
    942
    45
    I think the only differences coilover wise are between the Quattro and 2wd fitments and whether your car has a 50mm or 55mm strut.
    I run JOM's and they're excellent for the money.
  4. TimG
    TimG Active Member
    942
    45
    Damian, I have been looking through the DPM site this morning at FK Highsport's. I wanted to check that the Sportback and 3dr A3's are the same suspension fitment?
    Second, I noticed that on the site the 1.9TDI and 2.0TDI are offered as 50 and 55mm fitments. I thought all 1.9's were 50mm and all 2.0 were 55m? Now I'm confused!
  5. TimG
    TimG Active Member
    942
    45
    Actually have figured this out out now, don't worry!
  6. 8385HJ
    8385HJ Member
    101
    Thanks Damian appreciate it. Is the suspension for the s-tronic/dsg any different?
  7. 8385HJ
    8385HJ Member
    101
    What fitment is a 170bhp 2.0tdi mate?
    thanks in advance
  8. DPM
    5,033
    208
    The DSG may have a heavier rate front spring over the manual but that's about it.
  9. DPM
    5,033
    208
    As in 50mm or 55mm?
    It'll most likely be a 55mm front strut but it's always best to check.
  10. 8385HJ
    8385HJ Member
    101
    @Damian - Thanks Damian i called the supplier of the coilovers and he said they will fit on the car i have and that they supply a DSG set up aswell. I need a part no. for the top mounts front and rear for the car any idea where i can get it from?
  11. DPM
    5,033
    208
    What price have they give you and for what kit? We may be able to beat it for you.
  12. 8385HJ
    8385HJ Member
    101
    @Damian - They are FK AK street coilovers for £200 including delivery, if you are able to let me know that would be a great help. Thanks
  13. DPM
    5,033
    208
    We'd match that price for you.
