Coilover questions
190sline Nov 18, 2012
  1. 190sline
    190sline Member
    53
    Hi guys I think I'm guna go the coilover route. Is there anything I need to buy other than the actual coilovers? Thanks mat.
  2. Andi25th
    Andi25th Member
    227
    17
    Your better off replacing the top mounts and bearings whilst its all coming off.
  3. 190sline
    190sline Member
    53
    Sorry I forgot to put mine Is a Quattro will that make much difference to anything else I need to buy?
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,230
    171
    I don't think there are top mounts and bearings.
  5. Jp-tqs
    Jp-tqs Member
    183
    Hi mate, do you really need coilovers? The only reason in my opinion, to get coilovers is they are adjustable. Are you ever going to adjust them? Personally, think a quality damper/spring combo is the way forward. A sh*t set of coilovers will ruin your car! Whats your budget mate?
  6. renorti
    renorti Member
    40
    cheap coil overs are appealing, because they are cheap! better off saving a few more pounds get a proper set of shocks{koni, bilstein} and lower springs{25-40mm} used cheaper coil overs on vw mk4 golf, car handled well, but always get a bumpy ride with them
    was never totally happy with them no matter how i adjusted them.
    recently put koni sport shocks on a 530d{e60} and its lovely, ride is excellent and the big heavy lump does not bounce around at all.
    not cheap, but worth it.
  7. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Coilovers allow you to set the ride height exactly where you want it unlike springs and dampers which are obviously fixed. A friend of mine is running Bilstein and Eibachs on his avant and the rear isn't as low as he would like it and there isn't anything he can do about it.
    I'm running AP coilovers, which are cheap but the quality and the ride is excellent.
